Old three phase motors and Variable Frequency Drives (VFD)
Forum topic by TopamaxSurvivor posted 1142 days ago 5529 views 0 times favorited 35 replies Add to Favorites Watch
TopamaxSurvivor
13192 posts in 1841 days
1142 days ago
Topic tags/keywords: three phase 3 phase motor vfd
I was working on a job this week where they were adding VFDs to some equipment with 25 year old 3 phase motors. These motors have been in daily use and working just fine since installation. Here comes the risk of using a VFD on an old motor; one of them worked OK, but the other tripped out showing ground fault as soon as the drive was started up. It was temporarily reconnected to line voltage and a new drive rated motor ordered.
Sometimes you win and sometimes you loose using drives on old motors. The motor insulation is seeing voltages as high as 1,000 volts. It was designed for 480. Of course the switching cycle of the transistors can be in the megahertz range. That doesn’t help the older motor either.
I just thought I would mention this for those who are considering old three phase equipment when the live in a single phase world.
That motor would probably run on a mechanical rotophase. It is anybodys guess as to how much longer it would have run. An electronic megaohm meter shows a dead short, but it works on the same principle as the drive. A regular ohm meter shows it being just fine.
35 replies so far
View UnionLabel's profile
UnionLabel
660 posts in 1366 days
#1 posted 1141 days ago
Topamax, just a question. Was the power in connection Delta or Wye? Only asking cause I’ve seen some high phase Delta here that does some weird stuff to old machinery. Don’t know that much about it, but I know an industrial electrician who has run into three phase motors that acted just like you explained. Like a dead short.
Same thing, close or not so much?
-- Methods are many,Principles are few.Methods change often,Principles never do.
TopamaxSurvivor
#2 posted 1141 days ago
All most all pwer connections are Wye these days, at least here in Water World.
The motor is does have a dead short at the voltages teh drive is butting out.
View dfarr's profile
dfarr
19 posts in 1597 days
#3 posted 1140 days ago
VFDs introduce transients with extremely fast voltage rise times into the circuits that can quickly destroy the insulation in older non-inverter duty motors. There have been many motor design improvements since VFDs came on the scene once it was apparent that drives are here to stay. Inverter duty motors have design changes like increased winding slot insulation, increased first turn insulation and increased phase-to-phase insulation to withstand peaks of up to 1600 volts. Another frequent mistake made is slowing older motors down below 1/2 rated speed (<30HZ) which creates overheating due to the motor fan not moving enough air.
View studie's profile
studie
603 posts in 1312 days
#4 posted 1140 days ago
Your vocabulary is too copious for my immediate comprehension, please illusidade!
-- $tudie
TopamaxSurvivor
#5 posted 1140 days ago
I tried to keep it as simple as possible. Bottomline, you are always taking a risk putting a drive on an old motor. Sometimes you wins and sometimes you looses ;-))
View jerryz's profile
jerryz
164 posts in 1444 days
#6 posted 1140 days ago
Ahhhhh, my good friend, unfortunately it is pretty much like tossing a coin in the air and picking heads or tails.
That’s the nature of the beast.
Happy Easter to everyone….
UnionLabel
#7 posted 1140 days ago
Tanks Tomamax, I wuz just axin’ fur my own persuites.
View ToddTurner's profile
ToddTurner
144 posts in 1488 days
#8 posted 1140 days ago
25 years ago VFD’s were very new. The motors built for that time usually were made for the standard 50-60hz operating range. A good VFD can be infinitely adjusted from 0-120 hz. THose old motors will not take it. Trust me, been there, done that. Im just wondering where you are using a VFD in a woodshop? Im always in for great ideas and i have access to all kinds of drives.
View ondablade's profile
ondablade
103 posts in 1364 days
#9 posted 1140 days ago
It may be a little different to the US, but over here in Ireland i’m using a 4kW Omron/Yaskawa V1000VFD to step up the rpm of the 3 phase 50Hz motor on the Bill Pentz dust sysytem i’m building from the standard 2 pole 2850 rpm to the 3,450 rpm you get on the US 60Hz motor the blower was designed for.
The variable speed is incidental so far as i’m concerned, it’ll be set and forgotten. The VFD does have some other advantages however from what i’ve read in recent weeks though:
1. The programmable soft start the VFD almost eliminates the additional current drawn by the motor on start up. (it would draw six times the full line current if started normally DOL or direct on line) This is important for me as i would otherwise risk popping the incoming 62A fuse on my 220V single phase supply.
2. A decent VFD gives very high levels of protection in the event of overloading and so on. It also avoids the need so far as i know for an NVR (no voltage relay – drops the contacts out for safety in the event of loss of supply) in the starting switch as it contains this function.
3. They give more or less full torque right down to the lower RPMs – but you need to be careful about the limited cooling that results from lowered fan RPMs.
The downside my supplier said is that it’s not reckoned to be a good idea to run a cheap eastern or old motor with one, presumably because of the insulation and other extra stresses it can result in if run over or under the stock RPM.
It also happens that for the majority of single phase to three phase VFRs that don’t step up the voltage (i for example am getting 3 phase power at our single phase 220V – instead of the usual 380V) you need a dual voltage motor connected in delta. This isn’t an issue for most modern motors, but older and cheaper motors may not have this facility.
The reason for this is that to get the same HP at 220V as 380V the windings have to handle a much higher current – which in the specific situation where old three phase motors are being run on single phase power via an inverter without a voltage step up transformer is presumably the reason they often quit.
Don’t ask any complicated questions as this is just what i’ve gleaned in the past week – i’m no expert!!! :-)
ian
-- Late awakener....
View jockmike2's profile
10636 posts in 2412 days
#10 posted 1140 days ago
Also older model Delta Lathes had VFDs on 2hp motors that ran off 110volts. I had a b*ch of a time trying to replace it when it went too. Had to buy a whole different system and run it off a 30 amp ac line. But at least it work and works good now.
TopamaxSurvivor
#11 posted 1140 days ago
notottoman You can have the motor checked with a mega-ohm meter. They operate at high voltage. If it doesn’t read close to infinity, the motor will probably not run with a drive.
ToddTurner IMO, drives are getting so cheap, they make roto-phases and converters obsolete. They are so much more versatile.
View stefang's profile
stefang
9436 posts in 1499 days
#12 posted 1130 days ago
It’s all geek to me.
-- Mike, American in Norway
View paleoelectronics's profile
paleoelectronics
6 posts in 544 days
#13 posted 544 days ago
New to this chat room and although not really a woodworker myself, I am an electrician who helps a lot of my cabinet building and blacksmith buddies with the ancient equipment that they pull out of barns around here. I am trying to find help about a VFD problem Im having with Chinese equipment in a brewery that I’m doing some work on. Its a 4.4 HP 220/480 volt Chinese motor transmission assembly that has been making a clanking sound when wired in the lower voltage ( Delta) configuration. This matches the system voltage which is a delta High leg. The drive operating this motor is a 5HP drive from Automation Direct. The unit operates poorly and will fault out on overload after a short while. However when this same unit is wired in the Wye configuration it operates properly with no noise whatsoever. I was impressed with the expertise I have read in this thread and was wondering if you could help me with this problem before I go bald from scratching my head
TopamaxSurvivor
#14 posted 544 days ago
That is wild!! :-)) I’m not sure, but I would suppose it has something to do with the high swiching ferquency of the drive that is se the ground fault wired delta. Any reason you can’t just wire it wye and forget it?
paleoelectronics
6 posts in 544 days
#15 posted 544 days ago
Yeah my intuition on it is that its causing some sort of ringback noise from the motor. A pal of mine has suggested an inductor on the output as a filter but before I start throwing extra parts on the system I would like to know why its doing this. We can and will run it in Wye but there is HP loss when you do that and the german in me tells me that its not proper to run a device differently than its designed for. Seeing as we have several of these out in the field I would rather be prepared for the next time this comes up
showing 1 through 15 of 35 replies
