making smooth transition in square leg
« back to Woodturning forum
Forum topic by Belg1960 posted 05-11-2016 12:45 AM 882 views 0 times favorited 12 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1058 posts in 2968 days
05-11-2016 12:45 AM
Guys, I was wondering how do I make the nice curve from the cove to the square part of the leg? No matter how slow and thin a cut I take I keep chipping out the corners. These are being made for some farm tables out of 2x material. This is what I’m trying to do . Thanks for any help.
-- ***Pat*** Rookie woodworker looking for an education!!!
12 replies so far
View Rick_M's profile
Rick_M
11085 posts in 2282 days
#1 posted 05-11-2016 01:26 AM
What’s your speed?
-- http://thewoodknack.blogspot.com/
Belg1960
#2 posted 05-11-2016 01:37 AM
1250 on a midi lathe.
Rick_M
#3 posted 05-11-2016 01:50 AM
Way too slow. I’d be around 3000. Try it.
View tyvekboy's profile
tyvekboy
1718 posts in 2916 days
#4 posted 05-11-2016 02:28 AM
Besides a faster speed, I would also cut from square side INTO the bead. That might also help.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
View LeeMills's profile
LeeMills
503 posts in 1204 days
#5 posted 05-11-2016 10:18 AM
and very sharp tools…
good video by Alan Batty on pommels.
https://www.youtube.com/watch?v=KfeLAHQSbqk#t=15
Belg1960
#6 posted 05-13-2016 10:11 AM
guys, thank you very much for the great advice and the video link. Are there any other really good beginner turning videos you could recommend?
Rick_M
#7 posted 05-24-2016 05:39 AM
Belg1960
#8 posted 05-30-2016 09:00 PM
So, any luck?
- Rick M.
Not at all Rick, I wond up scaring the heck out of myself. I was using glued up construction lumber and the live center walked out of the end twice and went airbourne. I was told that there is a better live center than the one I was using.
Rick_M
#9 posted 05-30-2016 09:20 PM
If you are using the live center in the picture, I’m less fond of those for general spindle turning because they can wallow out the center point and increase vibration which wallows out the center even more and can lead to the spindle popping off the tailstock. I prefer cup centers for general spindle turning. But whatever center you use, keep checking the tailstock and tighten if necessary.
View BlazerGator's profile
BlazerGator
20 posts in 1091 days
#10 posted 05-30-2016 10:15 PM
Sorry, no turning experience, so my thought may not be very valuable … if you’re worried about blowing out the corners when turning, maybe you could relieve those edges first with a chisel to reduce the amount of material you’re taking off on the lathe.
Good luck.
-- Blaze
View Nubsnstubs's profile
Nubsnstubs
1245 posts in 1632 days
#11 posted 05-30-2016 10:59 PM
Sorry, no turning experience, so my thought may not be very valuable … if you re worried about blowing out the corners when turning, maybe you could relieve those edges first with a chisel to reduce the amount of material you re taking off on the lathe.
Good luck.
- BlazerGator
Sorry Gator, post #3 nails it. That’s the proper way to do it.
Belg, I don’t know why the piece took flight, but you need to verify that the tail stock is locked tight, and the quill should be in pretty snug. The head stock attachment, spur, face plate or chuck should also be secured properly. The most important thing to remember at 3000 rpm, your piece should be centered, or it will want to come outta there…...... Keep it up, and you’ll get the fundamentals figured out quicker than you realize…....... Jerry (in Tucson)
Belg1960
#12 posted 05-31-2016 11:46 AM
Guys, thank for the advice. The tailstock was tight and it never budged from its original position. I think because it was so soft it just walked its way out. the second time I even added a c clamp to make sure it didn’t move. Could the fact that it was a midi lathe with an extension have anything to do with it? Its not bolted down to anything maybe it flexed enough to release the piece?? Could you post a picture of the style better suited for turning softer wood?
Blaze I had used a pull saw on a past project to do just that but was hoping to do it with the lathe tools like it should be possible. Thank you for your thoughts.
