Waterstone Storage?
Forum topic by rpmurphy509 posted 351 days ago 185 views 0 times favorited 10 replies Add to Favorites
View rpmurphy509's profile
rpmurphy509
292 posts in 383 days
351 days ago
Topic tags/keywords: question sharpening
Just got some waterstones from Lie-Nielson, not sure how best to store them.
I’ve asked around at work and have gotten two very opposite answers, figured
I’d get you alls opinions on this.
Is it o.k. to store them submerged in water so they are ready when I need them?
-- Still learning everything
View mot's profile
mot
4851 posts in 565 days
351 days ago
I store mine in water so they are ready to go. As long as they don’t freeze, that’s the way to go.
View Chip's profile
Chip
1058 posts in 621 days
351 days ago
I do that to rp. I just have a tupperware container with a lid. I try to keep the water around them evenly by standing them on edge. Not sure why exactly but I thought it made sense to keep them wet evenly and not rubbing each other.
-- Better to say nothing and be thought the fool... then to speak and erase all doubt.
View rjack's profile
rjack
110 posts in 383 days
351 days ago
I do the same as Chip.
-- Roger - Havertown, Pennsylvania
13167 posts in 929 days
351 days ago
I keep mine in the store. I don’t own any.
rpmurphy509
351 days ago
It’s settled then, storage in a sealed container covered in water is it, unless I don’t own them,
then they’ll stay at the store in their original packaging.
Thanks all!
-Ray
P.S. My apologies to the forum, just realized this was posted
in the design area. No clue how I missed that, but I did…
View Dorje's profile
Dorje
1749 posts in 525 days
351 days ago
I keep anything up to 1000 in water – the finer stones do not need to be soaked in water, you can just spray the surface before use.
View jaws's profile
jaws
4 posts in 350 days
349 days ago
Mine are all dry. Mostlly I don’t store them submerged as the 10 minutes or so to soak them before use is not a big deal for me. That way I can take them with me if needed. Artificial stones are fine to store submerged. It’s more of a preference.
I never store my natural stones submerged.
-- Joe, Oakland, CA
rpmurphy509
349 days ago
These are artificial stone. I never go anywhere with them, and it seems I am always sharpening something in the shop.
Dorje
348 days ago
If they’re soaked, they’re ready to roll…the reason I don’t store my 3000 and 6000 on water is because they’re mounted to a backing, which would fall off if left in water…(it’s happened before)...That said, I should correct what I said above…I store all my water stones that are not mounted to anything – in water, so they’re ready to roll. I want them at the ready. The finer stones that are mounted don’t really need to be soaked…
I’m working with all Japanese water stones. I like to keep them in a deep tupperware, just under the work bench, and I use them with a bench hook on the bench…Garrett Hack had a good idea for one
Also, if you haven’t done it already – keep materials to flatten the stones at the ready! For example, a granite surface plate and/or plate glass and wet-dry sandpaper. Those Norton flattening stones work well too…though you have to flatten them occasionally as well.
View Mike Lingenfelter's profile
Mike Lingenfelter
403 posts in 642 days
348 days ago
I don’t use mine that often so I store mine dry. I did store mine wet once and had problems with my 8000 stone. I pulled it after a couple of months in water and the outer surface had soften. It took a lot of work to sand it off and get it flat again. Also, unless you keep your water really clean, I don’t like to leave my stones stoking in all of that mess. As Joe said you only need a 10 minute soak to use them. I just put them in water as soon as enter my shop.
-- http://theinquisitivewoodworker.com/
Bookmark And Share This Page
