Delta 40-440 purchase?
Forum topic by 10Feettall posted 04-02-2010 02:17 PM 2625 views 0 times favorited 4 replies Add to Favorites Watch
View 10Feettall's profile
10Feettall
11 posts in 3169 days
04-02-2010 02:17 PM
Topic tags/keywords: jig bandsaw scroll saw
I’ve been looking to pick up a band saw for light woodworking. In my search, I’ve found a Delta 40-440 that I might be able to pick up dirt cheap. Will a 40-440 handle 2×4s?l
I know – some will recommend to get both a band saw and a scroll saw – but for a small shop and a smaller budget, it seems like the 40-440 is beefy enough to handle my needs for awhile.
Anyone have experience with this saw?
-- Eagan, MN
View Tim Gates's profile
Tim Gates
38 posts in 3070 days
#1 posted 04-19-2010 05:14 PM
I just finished rebuilding one (see my page) but I haven’t used it much yet. I got it more for the experience of rebuilding it because I have not really needed one in the shop. In any event, the saw can handle 2×4’s with no issue. As a matter of fact, these saws can be fitted with a different set of (Delta) guides and then you can mount a jig saw blade (in bottom jaw only). That would be plenty aggressive.
IMHO, the MOST versatile saw for a small shop is a radial arm saw. A decent saw used properly will make all the cuts with good results. Of course there are many that would be horrified at the prospect of using a RAS but the issues with the design are nothing that common sense won’t prevent. The “hazards” are similar to using a table saw without a guard (as most do).
What are you planning to do with it?
10Feettall
#2 posted 04-26-2010 05:17 AM
I missed the jigsaw on the auction, but I did pick up a 50 year old band saw – so I’m off to get that up and running with new tires and a custom-ordered 78” blade.
-- Eagan, MN
View Corasco's profile
Corasco
1 post in 350 days
#3 posted 07-07-2017 03:45 PM
Tim:
I just bought a 1950’s 40-440 and failed at installing a blade (it had none). I also think I may have dropped/lost a part in trying this. Could I call you or ask you to call me to discuss the parts, or could we e-mail to figure out what I have done?
I loosened the two screws in the square upper blade holder sleeve (one is a thumb screw and the other is a slotted screw) and now there is only one “square part” (flat on oneside and champfered on the other with a threaded hole in the middle) left on the table.
My son was helping me and he tried to install a blade with pins but I believe this machine uses flat blades; is that correct?
Is this something you or others might be able to help on?
Many thanks in advance.
Kit
-- Kit
View MrUnix's profile
MrUnix
6767 posts in 2226 days
#4 posted 07-07-2017 05:28 PM
Tim:
I just bought a 1950 s 40-440 and failed at installing a blade (it had none). I also think I may have dropped/lost a part in trying this. Could I call you or ask you to call me to discuss the parts, or could we e-mail to figure out what I have done?
- Corasco
Given that this thread is about 7 years old, and Tim hasn’t posted since 2011, I wouldn’t hold your breath waiting on a response from him :)
In the mean time though, you could always consult the manual(s)... try looking over at the VintageMachinery site where there is lots of documentation, such as this instruction manual: No. 40-306 & No. 40-440 Delta/Rockwell 24-inch Scroll Saw
