Homemade Router table question, and shop pics
Forum topic by SomeClown posted 04-02-2010 06:17 AM 2944 views 0 times favorited 2 replies Add to Favorites Watch
View SomeClown's profile
SomeClown
63 posts in 2974 days
04-02-2010 06:17 AM
Greetings,
Just a quick introduction to say that I recently became a member, and am loving every minute of all the posts, pictures, wisdom, etc. I’m new to woodworking (needed a hobby other than my day job… computers) and am in search of many, many answers to many, many questions, but for now I’ll just start with a couple.
I’ve decided to build my own router “table” into my existing workbench (photos below) and to that end bought some things I’ll need like a fence, t-tracks, miter track as well as some things I want like the 7518 router, Bench-dog Pro lift, Freud bit set and some other insundry parts. My thinking is that I’ll finish off my workbench (which has a 3/4” plywood surface) with another 3/4” finish quality plywood, and some trim. Considering I built the thing with 4×4s, deck screws (mostly… unti I brought out the big framing gun) it should be fine (I can park my bike on it with no flexing as it stands now.) So:
(1) I’m confused a bit as to how I should cut out the opening for the router lift plate number one. I have ideas ranging from a straight bit and template, to sabre saw, to voodoo magic. None are fully formed plans yet, however. I mostly stare at my parts and contemplate.
(2) Cutting the grooves for the T-Tracks and Miter: straight-edge and the appropriate router bit?
(3) Standard distance for the tracks from one another and in relationship to the router bit?
And now some pictures. First one here is of the bench section (right of photo) where I’ll put the router lift (might have to click links to get the full effect… the forums seem to chop so the two following photos look the same.)
Shop1
Next is a close-up of the same area:
Shop2
And a bigger view of the whole workbench—there’s a lot of it—where I also plan to add a miter-saw station at some point, somewhere:
Shop3
And toys:
Shop4
And more:
Shop5
And of the other end of the “L” workbench, along with a big set of shelves I built at the same time. Nothing fancy here, and certainly not up to any actual woodworking standard—more construction—but it works for me as I get going. Now I actually have some places to put things as I contemplate the more fancy options available to me:
Shop6
That’s it for now. Hope you enjoy!
-- There are 10 types of people in the world: those who understand binary, and those who don't.
2 replies so far
View live4ever's profile
live4ever
983 posts in 3004 days
#1 posted 04-02-2010 08:38 AM
Good times!
Cutting out the opening for the plate can be a bit tricky. If you’re willing to spend $10, you can save yourself some trouble and order the router plate template from Rockler. I believe Rockler plates and Benchdog plates and the Benchdog lift all share the same dimensions, but you should check that. For me, it was worth the $10 – trying to figure out a plan for making an appropriately sized template is trickier than one might think – it’s much easier if you have a variety of bits and guide bushings at your disposal but for me that wasn’t the case.
Yes, you can cut the grooves with straightedge and a straight bit. Or an edge guide for your router, if you have one.
As far as I can tell, folks usually have their miter track between 5 and 6 inches from the bit. Doesn’t seem to be an exact standard…
HTH, and good luck! And welcome to LJ! I’m fairly new here as well but it’s a tremendous community. You will learn so much so quickly.
View woodworm's profile
woodworm
14468 posts in 3585 days
#2 posted 04-02-2010 09:54 AM
In addition to method mentioned by live4ever, you may read this Tips & Trick of Installing Router Plate on a Router Table.
http://www.newwoodworker.com/instrtrlft.html
I hope it would help..!
-- masrol, kuala lumpur, MY.
