How to fill the void?
« back to Woodturning forum
Forum topic by Mark posted 05-09-2016 11:11 PM 676 views 0 times favorited 4 replies Add to Favorites Watch
View Mark's profile
Mark
967 posts in 2153 days
05-09-2016 11:11 PM
Afternoon all….if it is where you are.
I’m turning a Cherry Vessel that has 2 voids near the top, one quite a good size. to make matters worse there is a bit of punky wood on the edge of each void. I’m thinking of filling them with coffee and epoxy. i would like to use brass filings (from the key cuter) but am not to impressed with the lack of shine. I’m thinking’ I should remove as much of the rot as possible? I was going to use masking tape for backing for the coffee mixture? Any thoughts or suggestions would be great.
Thanks.
-- Mark
View Druid's profile
Druid
1900 posts in 2973 days
#1 posted 05-10-2016 12:40 AM
Hi Mark, regarding your question on the punky wood, if you really want to try and keep it, have a look at Minwax® High Performance Wood Hardener. It’s specifically for dealing with wood that is no longer as sound as it should be.
Here’s one link to their information . . .
https://www.minwax.ca/wood-products/maintenance-repair/minwax-high-performance-wood-hardener
If you don’t want to keep the wood for the visual effect, then get that carving knife out and create a pleasing shape where you will be filling in.
Interested to see the final outcome.
-- John, British Columbia, Canada
View Snowbeast's profile
Snowbeast
96 posts in 1516 days
#2 posted 05-10-2016 02:18 AM
Or you could try soaking the punky wood with thin CA glue and let it harden. Then fill the voids with the epoxy.
Personally, I would try to mix some Pearlex powder into the epoxy and get a nice, bright contrasting color on the fill material. To me, those voids are too large to look good with the coffee/epoxy blend.
I look forward to seeing the end product, no matter which way you go.
View gwilki's profile
gwilki
226 posts in 1652 days
#3 posted 05-10-2016 02:31 AM
Instead of using masking tape to support your filler, try inserting a balloon into the vessel, then inflating it. I’ve had good results with this method for smaller voids, and it should work for your bigger ones, I think.
-- Grant Wilkinson, Ottawa ON
View Mark's profile
Mark
#4 posted 05-10-2016 03:22 AM
Those are 3 excellent ideas.
1) Druid. I don’t much care for the mouldy wood look, so I have already taken the carving tools to the crud.
2) Snowbeast, I’ve never heard of the Pearl Ex till now. I did a goole on it and that sounds like what I’m looking for.
3) Gwiki. Excellent thought. I’m gonna try that.
Thanks again gents. This may take a while but I’ll post when it’s done.
-- Mark
