MicroJig Splitters
Forum topic by ardbeg posted 04-02-2010 04:55 AM 1183 views 0 times favorited 4 replies Add to Favorites Watch
View ardbeg's profile
ardbeg
102 posts in 3021 days
04-02-2010 04:55 AM
Does anyone have experience with either the Pro Steel Splitter or just the standard one? This seems like an easy-to-use safety item to install in your zero-clearance inserts. Sort of the best of safety and convenience (if it works).
http://www.microjig.com/products/mj-splitter-steel-pro/
I have a Jet saw that only has 1/4” depth for the throat plate—don’t know if that will be problematic.
Thanks folks,
Gus
-- You may delay, but time will not. --Ben Franklin
View John Gray's profile
John Gray
2370 posts in 3879 days
#1 posted 04-02-2010 05:11 AM
I have the Pro Steel Splitter on my table saw and haven’t had a kick back problem since it has been installed.
I’ve had the standard one for a couple of years but never installed it, the Pro with the steel center just seems more sturdy to me. The 1/4” plate on your saw should be no problem.
View davidroberts's profile
davidroberts
1027 posts in 3479 days
#2 posted 04-02-2010 06:25 AM
I have the standard for 1/8” kerf. I’m happy for what it is. You have to be careful not to ream the holes in your throat plate. I ot mine slihtly loose and dipped the prongs in shellac, which coated them just enough for a better fit. The instructions call for a 1/2” board such as plywood for the template. I used 3/4” and it worked fine. I thought the instructions were well written but the process is a bit involved. If you follow the instructions step by step, you’ll be fine. The biggest advantage I’ve found is the jig really does act like a featherboard. You can feel the board you are ripping push snug against the rip fence near the end of the cut. One word of caution, if you are ripping a 6/4 or 8/4 board, the kerf cut can pull the jig out of it’s holes. There are two splitters that are only a few thousands difference in width. You can play around and see which one works best for you, or the application. Oh, and the prongs are about 1/4” long, just like your plate.
-- Better woodworking through old hand tools.
View ellen35's profile
ellen35
2738 posts in 3426 days
#3 posted 04-02-2010 12:47 PM
I have had one for the last year or so… no kickback and I hardly know it is there!
John Gray
#4 posted 04-02-2010 03:42 PM
l should have posted this link in my 1st reply it’s a review I did of the Pro Splitter you might want to check it out.
http://lumberjocks.com/reviews/1269
