Bevel Guide fell off new saw...how to fix?
Forum topic by jwyant posted 05-09-2016 01:47 AM 782 views 0 times favorited 7 replies Add to Favorites Watch
View jwyant's profile
jwyant
18 posts in 956 days
05-09-2016 01:47 AM
Topic tags/keywords: question tablesaw
Hello fellow forum members. Well, I am so excited to have purchased my first ever table saw, the Delta 35-725. I have not completed the assembly yet and I just noticed that the bevel measurement curved sticker, that is on the front panel, fell off and is on the floor.
I want to make sure that the guide is accurate. I’m sort of freaking out now that it will not be true. I have not gone through any square/tuning steps yet.
How can I assure that the sticker is put back on correctly?
Thanks!!!
7 replies so far
View Woodchuck2010's profile
Woodchuck2010
722 posts in 1060 days
#1 posted 05-09-2016 01:56 AM
Pretty sure once you get it set up, raise the blade all the way up. Using a square, adjust it to 90*. Place the sticker back on making sure it aligns with the pointer on the bevel wheel. Maybe use some glue or more thin double sick tape to secure it.
-- Chuck, Michigan,
View waho6o9's profile
waho6o9
8523 posts in 2778 days
#2 posted 05-09-2016 02:03 AM
This might help you as well:
View hotbyte's profile
hotbyte
991 posts in 3177 days
#3 posted 05-09-2016 10:45 AM
Also, the indicator is adjustable so you don’t have to be perfect with re-attachment. I only us mine to get close and use a Wixey or square.
View Woodbum's profile
Woodbum
834 posts in 3267 days
#4 posted 05-09-2016 11:22 AM
It is only meant to be an approximate guide for setting bevels. I would never just accept the angle as shown on this low tech part of the saw. Set up your saw bevel cuts with a drafting triangle, a protractor and bevel gauge or better yet with an electronic “tilt box” such as the Wixey unit as shown in the post above. This , IMHO is one of the best advances to machine set up EVER. Get one and you will not be disappointed. Good luck, work safely and have fun!
-- "Now I'm just another old guy wearing funny clothes"
View SlickTX's profile
SlickTX
9 posts in 1235 days
#5 posted 05-09-2016 07:49 PM
- Woodbum
Ditto. I couldn’t be more happy with the Wixey that I use with my Delta 36-725. It really makes a difference.
View teejk02's profile
teejk02
486 posts in 1327 days
#6 posted 05-09-2016 09:42 PM
- Woodbum
Ditto. I couldn t be more happy with the Wixey that I use with my Delta 36-725. It really makes a difference.
- SlickTX
Kinda requires the saw to be perfectly level to the floor doesn’t it? Or do you calibrate to zero on the table and then move the blade? Dunno about the newer Deltas but the old ones wanted that blade alignment to be done with a simple tri-square…positive stops at zero and 45 accomplished with a small recessed set screw on the table that I actually forget was there.
jwyant
#7 posted 05-10-2016 01:37 AM
I would think that having the set to zero button would allow you to zero it out even if the table was a bit off.
Today, I believe I was able to get the blade alignment and the 45 and 0 degree stops set correctly using my combo square. I then started to install the front rail but ran out of time. :).
