Question on finishing room size
Forum topic by bonesbr549 posted 05-08-2016 11:14 PM 668 views 0 times favorited 9 replies Add to Favorites Watch
View bonesbr549's profile
bonesbr549
1557 posts in 3091 days
05-08-2016 11:14 PM
Quesiton, I’m designing my next shop that I will build from the ground up. I want to encorporate a seperate finishing room. What would be the minimum size you would consider.
I will be making some dressers highboys and other pieces in general that would be of size. I’m thinking 12×12 at the moment.
Thoughs?
9 replies so far
View Jerry's profile
Jerry
2654 posts in 1672 days
#1 posted 05-08-2016 11:21 PM
Okay, if you have a table saw, some tools a workbench, an assembly table, possibly a router table and dust collection, you are going to need bare minumum 20×20 just to be able to move around.
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
View AandCstyle's profile
AandCstyle
3069 posts in 2281 days
#2 posted 05-09-2016 12:02 AM
Bones, my previous shop had a 10’ x 12’ finishing room and it was mostly okay for size, but for the larger projects you mentioned it would have been very tight. Think about having 6-8 drawers spread around plus the cases. Also, I lined 3 of the walls with 2’ wide “drying” tables, then there is the door, the sink, storage for finishes, sprayer parts, etc. Then there was a 2’ by 2’ turn table in the center. Long pieces (bed rails) could present challenges. Do you tend to finish parts before assembly or after. Finishing parts before assembly requires more space. HTH
-- Art
bonesbr549
#3 posted 05-09-2016 12:47 AM
When the build lends itself I prefinish. I like the idea of lining 3 walls with tables. may have to think bigger 16×16
- Jerry
Probably was not real clear but I’m thinking just the size of the finishing room. The rest of my shop will be much bigger. Sorry for the confusion
View Jim Finn's profile
Jim Finn
2657 posts in 2946 days
#4 posted 05-09-2016 01:09 PM
I have a 12×10 finishing shed. One of those metal sheds for backyard use. It is inside a huge garage and works well for me. I have tables on three walls and find it fine for the small crafty items I make. You will want something larger or have a lot less tables in it.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Billy E's profile
Billy E
162 posts in 2104 days
#5 posted 05-09-2016 06:24 PM
I think 12×12 would be ok, provided storage for supplies is elsewhere. If you need shelf space, I’d add that in.
-- Billy, Florence SC
View pintodeluxe's profile
pintodeluxe
5702 posts in 2837 days
#6 posted 05-09-2016 07:26 PM
I would want a 12×12 if there were counters on no more than 2 walls. In other words 10×10 minimum floor space. Maybe a double door to roll big projects in on a dolly?
View jbay's profile
jbay
2333 posts in 923 days
#7 posted 05-09-2016 08:01 PM
As much space as you can sacrifice.
I have an area that is about 25×30 that I use for finishing, as well as laminating and other stuff.
I think at least 16×20 if you could. It’s nice to be able to spread everything out at once so that you don’t have to move stuff around in between coats.
Plus, I like to shade things after I stain them and being able to lay pcs parts out next to each other helps keep color consistant.
View OSU55's profile
OSU55
1697 posts in 2013 days
#8 posted 05-09-2016 08:33 PM
I use a 10×10 space for finishing, with one 5’ x 20” table. I think a 12×12 with double entry doors would be sufficient. A large table top may have to be leaned against a wall, but it’s doable. Something to think about – could a side and end wall be “temporary”, i.e. could be moved temporarily for a really large table or something? Since you are building it, incorporate 1 or 2 movable walls just in case.
View chiseler's profile
chiseler
124 posts in 912 days
#9 posted 05-11-2016 02:27 AM
I built my shop from the ground up without taking finishing into consideration. now the the plan is a 12×24 addition.
For now I bring my pieces to a friends shop for finishing,and his room is about 24×28
-- Scott.Triangle,NY Becareful and don't forget...They cut meat too! Ask me how I know
