Ground Level Deck
Forum topic by MrRon posted 05-08-2016 05:25 PM 611 views 0 times favorited 5 replies Add to Favorites Watch
View MrRon's profile
MrRon
4991 posts in 3363 days
05-08-2016 05:25 PM
Dear fellow LJs; First off, I am 81, so I’m not up to much physical labor. I also have limited resources. I want to build a ground level deck on my property (8 acres). In an effort to minimize physical labor and money, I have designed a modular deck. Each module would be 10’ x 10’; all perimeter boards and joists would be 2×6 PT, SYP. Joists will be spaced 12” on center and attached to the perimeter boards with strong-ties. Deck boards will be 1×6. Each module will sit on 4 concrete piers, set into the ground a distance that will result in a “floating” appearance. I intend to start off with one module and add on with additional modules as money becomes available. The way I have designed the modules will minimize the amount of “heavy” labor I have to exert. I also intend to have my 15 year old grandson do much of the work under my supervision. That will give him some woodworking experience. I estimated the cost of each module to be $270. After I have placed all the modules, I will band it all with 2×8 boards. The following sketch illustrates my plan. What do you think of the construction? I used 10’ as the maximum allowable span for a 2×6. Note: The solid black squares are the concrete piers.
5 replies so far
MrRon
#1 posted 05-08-2016 07:07 PM
Here is an additional sketch of one module.
MrRon
#2 posted 05-08-2016 07:09 PM
Duplicate post.
View marshallLaw's profile
marshallLaw
17 posts in 919 days
#3 posted 05-08-2016 08:08 PM
The recommended max span for a 2×6’ is 7 ft; and a 2×8’ is 9 ft per building codes. I would suggest placing a support member in the middle of each module to provide support and prevent sagging.
MrRon
#4 posted 05-08-2016 08:27 PM
The recommended max span for a 2×6 is 7 ft; and a 2×8 is 9 ft per building codes. I would suggest placing a support member in the middle of each module to provide support and prevent sagging.
- marshallLaw
According to my reference, a 2×6 SYP joist (#1 grade) is good for 10’-2” span when spaced on 12” centers. This is for a 50PSF live load + 10PSF dead load. A #2 grade is 9’-11” span and structural select is 10’-4” span.
117203 posts in 3697 days
#5 posted 05-08-2016 08:57 PM
As a 30 year contractor I build lots of decks,I think the difference of opinion is that marshall may not be taking into account that your joist are 1’ OC, never the less I think I would still consider perhaps bringing the blocks inward to make the span a little over 8’ and or add center support as Marshall suggested just to eliminate bounce .I don’t think a 2×8 is sufficient for supports on top of the pier blocks,normally I use 4×6, particularly with that kind of span.Most deck,decking surfaces are at least 2×6” material then joist are only necessary 24” OC for wood tops. I’m not sure of what your plans are for connecting your joist to your rim joist is but I recommend 2×6 LRU26Z hangers.
