Try my mortiser today!
Forum topic by Beginningwoodworker posted 04-01-2010 04:57 AM 1410 views 0 times favorited 34 replies Add to Favorites Watch
Beginningwoodworker
13345 posts in 3791 days
04-01-2010 04:57 AM
Topic tags/keywords: pine joining
I some sucess today with my benchtop mortiser, but not so good sucess with my tenoning jig. My tenons seems to be taper, I wonder why?
34 replies so far
13625 posts in 3459 days
#1 posted 04-01-2010 05:09 AM
charles ,
i always do the ends of the mortises first ,
that way the bit is going down straight ,
then eat a little at a time in the middle ,
moving it sideways .
the bit can flex , and why eat to much
at a time , it just messes with the tool .
as far as your tenons ,
looks like something isn’t square .
check your fence or the router for square .
i always make my mortises a little deeper than the tenons too ,
for a reservoir for the glue .
but hey , you are cooking now !
Beginningwoodworker
#2 posted 04-01-2010 05:13 AM
I am using a tenoning jig on my Unisaw.
#3 posted 04-01-2010 05:19 AM
check it or the blade for square .
probably the blade is off just a tad .
maybe some sawdust in the closing to 90 deg .
it gets in mine too ,
i clean it out before i come to 90 .
Beginningwoodworker
#4 posted 04-01-2010 05:20 AM
Ok I will check it.
View jm82435's profile
jm82435
1285 posts in 3860 days
#5 posted 04-01-2010 05:22 AM
I would suspect the blade is not at 90 degrees, or the jig is not holding your stock at 90 degrees…
-- A thing of beauty is a joy forever...
jm82435
#6 posted 04-01-2010 05:23 AM
wow I need to type faster, you two had a conversation while I was writing.
View dbhost's profile
dbhost
5766 posts in 3350 days
#7 posted 04-01-2010 05:54 AM
What they said…
View tomb's profile
tomb
2 posts in 3095 days
#8 posted 04-01-2010 06:07 AM
Just joined tonight. Been woodworking for a while but have been staying away from mortise and tenons and Dadoes. I am 68 years old, and need to get on the ball. I hope to learn from your experience. Thanks so munch in advance for any help.
-- Tomb. West Virginia
View jack1's profile
jack1
2109 posts in 4145 days
#9 posted 04-01-2010 06:08 AM
Is it a home made jig for the tenons? If not, you’ll be able to adjust that too if it’s a Delta or like that.
Beginningwoodworker
#10 posted 04-01-2010 06:13 AM
Its a Delta.
jack1
#11 posted 04-01-2010 06:19 AM
Which one, there are two. A big heavy grey one and a lighter one (about $30 diff) green maybe? Anyways, use a good fixed square and check everything for 90° to the table and that includes the blade. Take your time and check twice (read my motto ;o)...).
Beginningwoodworker
#12 posted 04-01-2010 06:25 AM
Tomb, Welcome! I got the 34-183, Jack.
#13 posted 04-01-2010 06:27 AM
charles ,
i do all my tenons with the dado blades ,
piece flat on the saw table ,
pushing down evenly , as the saw wants to ’ lift ’ the part slightly ,
and use a miter slider to push the part through the blades ,
with a backup screwed to the miter gauge for chip out .
with the fence set for the length of the tenon from the outside of the dado blades ,
and move the piece over until i get the whole thing done ,
then flip the part over and do the other side the same .
i ’ sneak up ’ on the thickness of the tenon ,
by raising the saw a little at a time ,
until it is good .
i found that using the jig you have ,
can let the blade ’ bend ’ in the long end grain cuts ,
and getting a ’ tapered ’ cut like you got .
Beginningwoodworker
#14 posted 04-01-2010 06:35 AM
I have wobble dado blade would that work?
View hazbro's profile
hazbro
109 posts in 3108 days
#15 posted 04-01-2010 06:38 AM
Charles, I don’t want do discourage you or demean you; but an english language jig would help you out a lot. My grammar is not perfect, I am a carpenter after all, but I’ve made it to job super without a degree. A little effort in the grammar and spelling can take your ground level know how and field skills to a professional level. If you can hone your skills and practice communication you can go far. Communication skills can take you farther than your woodworking skills.
just trying to help you out. you can go far.
-- measure once, keep cuttin' til it fits
showing 1 through 15 of 34 replies
