I am in the beginning phase of designing a chicken coop that I will build for a bunch of chickens that my wife just bought. There are a bunch of chicks in my garage as we speak, so I had better get moving!
I have most of the design in my head at this point and have begun working it out on paper. However, there is one part that I'm stuck on. I plan to build some nesting boxes to the exterior of the coop with a lid that lifts for access to the eggs. It's a pretty common layout like you see here: http://lumberjocks.com/projects/133650
In all the designs I have found, there is either nothing to keep water out of the hinge joint, or poorly designed attempts at it. We live in an area that can have some pretty rough winters, so it's not inconceivable for snow to drift up on top of the nesting box that would sit and slowly drip water over the seam.
I will either be using asphalt shingles or corrugated metal roofing - whatever is easiest - to cover the roof of the coop and the nesting box. What might be a good way to keep water out of that hinge joint?
Okay so check this out I'm a retired roofer.One detail you might consider is above he hinge joint you fasten metal called z- bar.Then you will get a piece of roof to wall metal.Then you can slide the roof to wall metal in and out as needed.
I think they might still the flashings in the roofing section at the Borg.If you need more description let me know.
Good luck looks like a fun project.
Okay so check this out I m a retired roofer.One detail you might consider is above he hinge joint you fasten metal called z- bar.Then you will get a piece of roof to wall metal.Then you can slide the roof to wall metal in and out as needed.
Thanks AJ2!
I looked up z-bar and have some ideas how it might be used in an application like this, but a little clarification would help. With the method you are describing, would you have to slide the roof to wall metal in and out every time you lift the roof, or are you saying it would slide in and out on it's own as you open and close the door? Maybe a picture would help if that's not too hard.
So here's what I was thinking .In the drawing they call metal flashing that what I was calling roof to wall it's usually bent at 110 degree angle for the slope of the roof.
You should be able to slide it in and out of the zbar easy peasy.
Hope this helps.
I built a couple of coops for my daughter-in-law and had the same dilema. I didn't spend much time thinking about sealing the doors because "Theys only chickens and a few drops of water ain't gonna hurt 'em".
I built a couple of coops for my daughter-in-law and had the same dilema. I didn t spend much time thinking about sealing the doors because "Theys only chickens and a few drops of water ain t gonna hurt em".
I was initially thinking the same thing, but then I realized these are the nesting boxes. They are smaller enclosed spaces with bedding and what not. I worry that once they get wet, they won't dry well and they will get pretty gross. I don't want my eggs in that, and I don't really want my chickens in it either. I'm not going to worry about the door seal so much, though. If water does work itself in there, it won't be much and it will dry out quickly enough and get cleaned regularly.
I think I've got my plan. I may go with the flashing that AJ2 is talking about, but the old inner tube idea makes perfect sense as well. Thanks for the input!
My nest boxes are built into the coop with a little drop down door that gives access to the boxes, so different than your plan. I built a little awning over the door so I don't stand in the rain while I'm collecting eggs.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
