Stanley Bailey #3 strange lever cap design
« back to Hand Tools forum
Forum topic by SurfHunter posted 05-06-2016 06:04 AM 1488 views 0 times favorited 18 replies Add to Favorites Watch
View SurfHunter's profile
SurfHunter
54 posts in 2287 days
05-06-2016 06:04 AM
Hello,
did a small roof repair and was paid in Hand planes !!!! Seriously…
On one of the 13 baileys I picked up today :), one of them stuck out to me.. It was the #3.
I noticed that the Lever cap has “Striated” pattern to it, I’ve never seen that before, thought it was pretty cool looking. Looks factory, just because of how its well placed.
Has anyone fabricated, etched, or engraved any of yours?
-- It’s not the hours you put in, but what you put into the hours that count.
18 replies so far
View albachippie's profile
albachippie
772 posts in 2909 days
#1 posted 05-06-2016 09:23 AM
Fairly standard Stanley design. Surprised the other 12 don’t have it!! It aids the seating of the chip breaker and iron. It also stops the blade creeping or loosening when adjusting the lateral angle of the plane iron
Quite a good design which I am sure Stanley must have patented. Haven’t seen it on any other planes I don’t think.
-- Garry fae Bonnie Scotland
View dhazelton's profile
dhazelton
2657 posts in 2170 days
#2 posted 05-06-2016 10:58 AM
The O.P. is talking about the finish in the metal. I’ve never seen it either. Was it not polished at the factory, and did they even polish them? Was there a run of painted units with that finish under the paint?
View bandit571's profile
bandit571
18924 posts in 2557 days
#3 posted 05-06-2016 11:09 AM
Those used to be nickle plated. Maybe someone had sanded of a flaking finish back to bare metal, with a beltsander.
albachippie
#4 posted 05-06-2016 11:29 AM
The O.P. is talking about the finish in the metal. I ve never seen it either. Was it not polished at the factory, and did they even polish them? Was there a run of painted units with that finish under the paint?
- dhazelton
My Mistake… Note to self… “Must Pay More Attention”
View BurlyBob's profile
BurlyBob
5148 posts in 2139 days
#5 posted 05-06-2016 02:31 PM
I tend to agree with bandit. Somebody took the finish off in a really rough way.
View onoitsmatt's profile
onoitsmatt
374 posts in 1050 days
#6 posted 05-06-2016 03:18 PM
I recently sold a Stanley 51 spokeshave on eBay with that exact pattern on the cap.
-- Matt - Phoenix, AZ
View Johnny7's profile
Johnny7
333 posts in 964 days
#7 posted 05-06-2016 08:25 PM
That finish is almost exclusively found on war era planes
Does the plane in question have any of the hallmarks of that era—rubber adjusting wheel, stained hardwood knobs, especially thick sidewalls?
Better yet do you have a 3-digit number stamped on the iron by any chance?
SurfHunter
#8 posted 05-06-2016 08:32 PM
I was thinking same thing, as far as someone possibly sanding down like that, if so, they did a good job, because it shows around the hinge as well.
I just thought it was different.
Matt, glad to see someone else with same pattern, yours appears smooth, mine is textured, Thanks for your posts and everyone’s replies.
Johnny7
#9 posted 05-07-2016 12:56 AM
Surf
So, what is the answer to the Qs I posted?
SurfHunter
#10 posted 05-07-2016 03:44 AM
Sorry Johnny,
I posted quickly, as I was running out the door. Yes the Iron has the numbers 341 stamped into it,
and although it doesn’t have the plastic knob, its not brass either.
SurfHunter
#11 posted 05-07-2016 03:59 AM
I see where they say the war plane lever caps where coarsely made
Type 17. Planes made by Stanley 1942-1945.
All of the features of the previous, except:
These are the war production planes, and all bets about what is and isn’t proper on these examples, and those made in the years immediately following, are off. This is an area where the type study is very weak, in my opinion. But it’s understandable since there are so many configurations of these planes. My observations tell me that any combination of the following features is possible for these planes. And, to make matters worse, some of the examples have the standard features (rosewood, brass) of the previous type in conjunction with some of the features of this type. This all is likely explained by the fact that Stanley was using stock on-hand, where parts made prior to the war were simply being used.
Handle and knob are hardwood stained red or painted black.
Depth adjustment now is smaller, made either of steel or hard rubber.
Oddly, the bottom castings are much thicker and heavier than other models.
The type study doesn’t mention this, but my experience tells me that nickel plated lever caps went belly-up during the war. The lever cap have a rather coarsely machined surface.
The type study also fails to mention this—the normal two-piece construction of a brass cap and a threaded rod, used to secure the wooden parts (tote and knob) to the bottom casting, is now a one piece construction (like a long screw).
Some examples have no frog adjusting screw. It’s strange that on the examples I’ve seen, the hole is tapped for the screw in the bottom casting, but the frog isn’t. It’s like they did half the work, but all for nothing. On other examples, neither hole is tapped.
Some examples have the old-style hole (keyhole-shaped) in the lever cap.
Johnny7
#12 posted 05-07-2016 01:46 PM
Exactly my point.
What you have is not the result of someone sanding it. The work-force during that time period consisted of mostly women, who were pressed into service and had to quickly learn the assembly line tasks previously done by seasoned employees. In addition to material scarcity (shipping embargoes made rosewood acquisition prohibitive; brass was used for munitions), other niceties like polishing and plating were foregone.
By the way, the “341” means that the iron, at least, (and probably the whole plane) was made in the third quarter of 1941.
bandit571
#13 posted 05-07-2016 02:03 PM
3rd Quarter of 41? US was NOT at war with anyone. No rationing in effect. Brass was still in the supply chain for stuff other than bullets.
Lever caps were still being plated with Nickle. Seen enough war planes come through my shop. Still have a Wards (Stanley) WWII #3 in the till. Lever cap was nickle plated. About 2/3s was flaked off, so I removed the rest. The adjuster wheel is the hard rubber version.
Number stamped into the iron is 444, 4 quarter of 1944. Wood is a stained hardwood. There is no patent date incised into the back of the lever cap. The steel handle bolts had been blued.
Lever cap has Wards Master cast in to in. Iron is stamped as a “Wards Master Quality” .
Toe has a “No.” on one side of the tall knob’s ring, and a “3” on the other side. Made in USA is behind the knob. There wasn’t a frog adjust bolt, nor was it drilled for one.
Anything else?
Johnny7
#14 posted 05-07-2016 02:34 PM
swing and a miss
Dec 8th, 1941 (the day after Pearl Harbor) we declared war on the Empire of Japan
The third quarter of 1941 includes all of December
bandit571
#15 posted 05-07-2016 05:17 PM
Math is way of…Pearl Harbor was in the FOURTH quarter of the year. As in Oct.,Nov., DECEMBER.
12 divder by 4…right? 3 months is one fourth of a year. Try again?
