Final Coat of Polyurethane
Forum topic by tommyc325 posted 05-06-2016 02:04 AM 1449 views 1 time favorited 12 replies Add to Favorites Watch
View tommyc325's profile
tommyc325
58 posts in 1503 days
05-06-2016 02:04 AM
Hi Everyone
I about 4 hours ago I applied my third coat of polyurethane to a walnut table top I made. After each coat I sanded down and vacuumed with 220 grit. Now that my third coat is dry I noticed there’s some air bubbles and some ruff spots that I would normally sand down but I wasn’t sure if I should sand this final coat.
My question to you is what do you suggest I can do for this final coat to get this table super smooth and keep the look that it has.
Thank You In Advanced.
Tom
12 replies so far
View Woodchuck2010's profile
Woodchuck2010
721 posts in 1005 days
#1 posted 05-06-2016 02:32 AM
I’d say the final coat is the last one you apply. Sand it and apply another coat if you’re not happy with the finish.
-- Chuck, Michigan,
View conifur's profile
conifur
955 posts in 1298 days
#2 posted 05-06-2016 03:04 AM
Well gives a hint, what are you using for a finish, oil, or water base?? How are you applying it???
Another freaking post, I want answers but not enough info!!! My Rant
Vacuumed, you should have wiped it down with a damp cloth with many different things, water, mineral sperits, Naphtha, ect.
tommyc325
#3 posted 05-06-2016 03:06 AM
Fast Drying Semi Gloss Poly Oil
Foam Roller
conifur
#4 posted 05-06-2016 03:14 AM
I never used it or applied that way, I bet the the combo is putting air bubbles in it and b4 they can air out, the Poly sets up. I would lightly sand them out, then use the Poly and cut it with Mineral Spirits, 50/50 and wipe it on for your final coat.
conifur
#5 posted 05-06-2016 03:21 AM
Also never shake a can of finish to mix, stir it, shaking puts air bubbles in it.
tommyc325
#6 posted 05-06-2016 03:22 AM
- conifur
I didnt shake the can
View WhoMe's profile
WhoMe
1564 posts in 3390 days
#7 posted 05-06-2016 03:32 AM
I usually avoid foam rollers, brushes, they have a tendency to make bubbles. That has been my experience. And the fast drying poly might be drying too fast for the finish to flow out and may trap any bubbles.
If you can sand out the bubbles do that and if you can thin the last coat, that may help prevent any possible bubbles that the foam roller may cause. Also, I usually sand with 320 on the last couple coats.
Just some suggestions.
-- I'm not clumsy.. It's just the floor hates me, the tables and chairs are bullies, the wall gets in the way AAANNNDDD table saws BITE my fingers!!!.. - Mike -
View BurlyBob's profile
BurlyBob
5917 posts in 2412 days
#8 posted 05-06-2016 03:35 AM
Let it dry hard, real hard. Give it a light sanding with 600 grit wet dry paper. Thin the poly down super thin. Get a piece of polyester cloth and fold so you get a 3-4 inch fold. Dip in the thin poly and use the fold as a squeegee to move the poly along the table top. If you can look across the top from the side you can see where you need to apply the varnish to give it complete coverage.
I’ve used this method for years and have been able to achieve extremely smooth finishes. I’ve also put the fold inside a piece of pantyhose to prevent lint in the finish.
Best of luck.
View RogerM's profile
RogerM
798 posts in 2546 days
#9 posted 05-06-2016 02:33 PM
Your poly is too thick. Dilute with an equal part of mineral spirits and put on another coat.
-- Roger M, Aiken, SC
View distrbd's profile
distrbd
2252 posts in 2593 days
#10 posted 05-06-2016 02:41 PM
- BurlyBob
Never tried it that way,thanks burlyBob.
-- Ken from Ontario, Canada
View AWood's profile
AWood
51 posts in 3893 days
#11 posted 05-06-2016 03:14 PM
Lightly sprinkle water on finish and lightly sand with 440 grit; wipe dry with damp cloth; apply a light brush finish of poly urethane and immediately go over with brush application with sponge.
-- AllWood
View pintodeluxe's profile
pintodeluxe
5757 posts in 2960 days
#12 posted 05-06-2016 03:20 PM
I agree with others to wet sand once fully cured. I use a spray bottle of tap water and a 1500 grit soft sanding sponge.
Applying poly with a roller would be the cause of the problem.
Hope it comes out okay.
