Plum Wood
Forum topic by JimWhip posted 05-05-2016 10:10 PM 1218 views 0 times favorited 4 replies Add to Favorites Watch
View JimWhip's profile
JimWhip
18 posts in 1330 days
05-05-2016 10:10 PM
Does anyone have any experience working with “Plum Wood?” We’ve had a wind storm go through Northern Utah here and a large fruitless plum tree went down. I’d like to know if the truck (the wood) is good for making things out off? I’m assuming I’d have to seal the ends and let it sit for a year to dry out. What would be best to use to seal the ends?
Thanks guys for your help.
Jim
-- Jim Whip
View DonBoston's profile
DonBoston
81 posts in 1612 days
#1 posted 05-06-2016 01:56 AM
I do a lot of vases with plum on the lathe… pens too.
Anchorseal the ends.
-- Don Boston RECreations by Don http://recreationsbydon.com
View Jim Finn's profile
Jim Finn
2683 posts in 3072 days
#2 posted 05-06-2016 02:02 AM
Any fruit wood like plum is great for carving. A woo carver can even use small pieces of it.
-- No PHD just a DD214 Website> craftingcouple.com
View BobAnderton's profile
BobAnderton
283 posts in 2940 days
#3 posted 05-06-2016 02:39 AM
Seal the ends and slab it as soon as possible. If you leave it in log form it will take forever to dry and it will be apt to develop cracks in the log when it does. 2” thick seems to be a good balance between what will stay straight and flat without checking (cracking), but the thickness will be a function of what you want to do with the wood. Stack it with stickers (1×2 slats) between layers and air dry it. If you are sure you want really thick pieces, like for turning, then cut thick slabs so that they don’t contain the pith (center of the tree).
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
View simmo's profile
simmo
69 posts in 3621 days
#4 posted 05-06-2016 05:05 PM
I have several cu ft of plum , when dry it can be used for any thing you like, think cherry wood , v similar, close grained takes an excellent polish, just used some for chisel handles ,
good stuff Chris
