Frequency of Waxing Cast Iron Tools
Forum topic by ardbeg posted 03-31-2010 03:00 AM 2840 views 0 times favorited 23 replies Add to Favorites Watch
View ardbeg's profile
ardbeg
102 posts in 3197 days
03-31-2010 03:00 AM
I am wondering how often those of you who have garage-based shops wax your table saws, jointers and other cast iron tools. I have been waxing mine every couple of days since I got mine and should really be buying stock in S.C. Johnson for how much wax I have been going through.
-- You may delay, but time will not. --Ben Franklin
23 replies so far
View NBeener's profile
NBeener
4816 posts in 3343 days
#1 posted 03-31-2010 03:09 AM
My most sincere answer would be … just enough to keep rust from forming.
I doubt that you can apply too much wax for cast-iron tops, but … I also don’t think you’d do yourself any favors by having too much build up.
So … maybe once a season … I might use a Scotchbrite pad with some odorless mineral solvents (even Simple Green or WD-40 would work), and give the tops a good scrubbing … down to the metal … and then re-apply.
I have a basement shop. Humidity down there tends to run between about 40 and 45%. I’m not having a rust issue, but probably wax the tops monthly or so … for pure protection … and … to keep the wood moving around fairly effortlessly.
A lot of people seem to think that a somewhat regular coating of something like WD-40 or Boeshield T-9 … with something like a Scotchbrite pad … or 0000 steel wool … will do the job as well as wax … without any potential for excess accumulation (“build up”) over time.
Haven’t tried it … but I DO switch to WD-40 as a winter chain lube on my mountain bike (bicycle), and—despite miles and miles of salty, slushy, snowy, icy conditions—don’t have any trouble with rust. During the winter, I tend to use the WD-40 after EVERY ride. It’s not a long-lasting lubricant, but … it’s not expensive either, so … I’m pretty liberal with it.
Good luck!!
-- -- Neil
View bigike's profile
bigike
4054 posts in 3458 days
#2 posted 03-31-2010 03:14 AM
for me i do it once every week ever since i got my new unisaw a year ago all my other tools my jointer i had for about four years now and only once same with my drill press. they have never rusted ever since i got them, well my drill press did cuz i drilled some acrylic and to keep it from melting you have to wet the bit if it’s not a plastic drill bit.
View Roper's profile
Roper
1389 posts in 3883 days
#3 posted 03-31-2010 03:23 AM
i live at7800ft so i don’t have much of a problem with moisture. i wax about once a month just to keep the wood moving , i will wax more if i am using alot of green wood.
-- Roper - Master of sawdust- www.roperwoodturning.com
View Michael Murphy's profile
Michael Murphy
453 posts in 3175 days
#4 posted 03-31-2010 03:25 AM
The wax should not build up. You are replacing the old coat with a new one. Put it on let it dry and buff with a soft cloth. Once you have a good coat, unless you have an active drip from a leaking roof, in which case fix the roof or buy a tarp, you should be good for a while. I redo mine every couple of months or if I notice the stock isn’t moving as easily.
-- Michael Murphy, Woodland, CA.
NBeener
#5 posted 03-31-2010 03:32 AM
Michael Murphy:
I was having doubts about that … even as I typed it.
Thanks for clarifying!!
-- -- Neil
View cstrang's profile
cstrang
1832 posts in 3338 days
#6 posted 03-31-2010 03:51 AM
I usually wax mine once a month or if it’s a slow day in the shop I will wax it even if it doesn’t really “need” it.
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
View Ger21's profile
Ger21
1075 posts in 3301 days
#7 posted 03-31-2010 04:03 AM
I use Top Coat, and only need to re apply it about twice a year. I really only put more on when I want it to be more slippery. I use it on all my cast iron tables, and none of them rust. I didn’t use my Bandsaw for about 8 or 9 years, and it didn’t have any rust on it at all when I recently got it running again.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
ardbeg
#8 posted 03-31-2010 04:07 AM
Thanks for the input guys—got to love LJ. Like Mr. Murphy said, I am not getting buildup due to buffing it. I am fascinated by this Top Coat. I tried Googling it and came up with a half dozen possbilities. Can you give me a link to it?
View Sawkerf's profile
Sawkerf
1730 posts in 3238 days
#9 posted 03-31-2010 04:26 AM
It’s all about the humidity in your shop. Here in the Bay Area of CA, it isn’t much of an issue and I get by with 2-3 cleanings and waxings a year with automotive paste wax. Your mileage may vary. – lol
View Steven H's profile
Steven H
1117 posts in 3230 days
#10 posted 03-31-2010 04:39 AM
I wax all hand tools and machinery twice a week.
View TungOilTim's profile
TungOilTim
83 posts in 3386 days
#11 posted 03-31-2010 06:01 AM
Having my equipment in a garage in Florida, it’s sometimes difficult to keep my cast iron not to rust. Since I am not as home as often as I’d like, I use some steel wool on the surface, then BoeShield T-9, then an automotive paste wax. Helps me since I can’t do it as often.
-- Tim, Plant City FL
View JimmyNate's profile
JimmyNate
124 posts in 3520 days
#12 posted 03-31-2010 07:13 PM
For work surfaces, I think it’s a matter of personal preference. I put Boeshield T-9 on all the cast parts inside the table saw because it is a dry lubricant as well as a rust inhibitor. The advantage of the dry lubrication is you don’t have sawdust stuck in the lube and making a mess of everything. This means you don’t have to clean it out and reapply as often. I”m coming up on 1 year since the first application and will probably clean everything up and recoat it soon.
-- "We are what we repeatedly do; excellence then is not an act but a habit." ---Aristotle
View Bryan_M's profile
Bryan_M
46 posts in 3213 days
#13 posted 03-31-2010 09:37 PM
Here in So. Cal. things don’t really rust so I just wax my stuff to keep them slippery. When stuff stops sliding around smoothly, thats when I wax.
View Padre's profile
Padre
930 posts in 3658 days
#14 posted 03-31-2010 10:35 PM
I wax once a month but make sure there is no buildup by using the same method as Neil
-- Chip -----------http://www.penmanchip.com-----------------Micah 6:8
View D1st's profile
D1st
291 posts in 3209 days
#15 posted 03-31-2010 11:17 PM
Sounds like a womans club in here. lol all this waxing going on. I waxed my head once when i shaved it on a regular basis. What a nitemare. lol What are some recommended waxes for the tables?
-- http://www.furstwoodworks.com/
