Ryobi AP 10 Planer problem
Forum topic by Craig75 posted 05-04-2016 10:55 PM 499 views 0 times favorited 0 replies Add to Favorites Watch
View Craig75's profile
Craig75
1 post in 807 days
05-04-2016 10:55 PM
The plastic nuts that hold the on/off switch intact, apparently broke and flew out of the planer during operation. Like an idiot, I panicked and turned off the planer while in use and broke the drive belt. I replaced the belt, but do not know how to safely access the inside of the motor shell to fix the switch mount. If I remove the eight 5mm bolts under the motor case, will I cause more problems than I already have? Repair suggestions welcome. Thank you. Craig 75
0 replies so far
