| Forum topic by Chris | posted 1144 days ago | 1176 views | 0 times favorited | 9 replies | ![]() |
1144 days ago |
I was having a discussion the other day and the question of how fast the outside edge of a bowl blank is actually moving came up I couldn’t remember the math… been to long. Do any of you lj’s or engineers remember the formula for that? Lets say that the lathe is running at 500rpm and you have a 6” diameter blank mounted; how fast is the edge actually going? -- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein |
9 replies so far
#1 posted 1144 days ago |
Here is my guess somebody is welcome to correct… Circumference = pi x diameter, so 3.14×6 = 18.84” circumference (distance around) If that is spinning 500 times in a minute , that = 9420 inches a minute. That equals 785 feet per minute. To have more fun… x 60 that equals 47,100 feet per hour…divided by 5280 = 8.92 miles per hour. |
#2 posted 1144 days ago |
How fast is the edge going? 500rpm. :-) But I guess you wanted miles per hour? Feet per second? -- Charlie M. "Woodworking - patience = firewood" |
#3 posted 1144 days ago |
Now to have yet more fun… If a 6” spinning bowl blank leaves chicago at 10:00 a.m heading for new york at 500 rpm, when will a 9” bowl blank leaving Chicago at noon heading toward New York spinning at 550 rpm pass the 6” bowl blank? (my brain hurts just writing that question…) |
#4 posted 1144 days ago |
In Pittsburgh? -- Charlie M. "Woodworking - patience = firewood" |
#5 posted 1144 days ago |
I guess I could have worded that better…. The real question would have been regarding velocity…. Tip speed in Feet p/Sec i guess…. versus the rpm. You see the discussion was regarding the proper rpm vs the blank size which kind of morphed into this side question. -- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein |
#6 posted 1144 days ago |
Do you mean, “for a specified tip speed and diameter, what should your RPM be”? Then it’s just a matter of rearranging the equation (solving for RPM) and boiling down the constants. For tip speed in feet/sec and diameter in inches: RPM = 229*tip speed/diameter -- My broker promised me he would treat my money as if it were his own. Trouble is, he did. |
#7 posted 1144 days ago |
13.08 feet per sec. |
#8 posted 1144 days ago |
The next question this raises for me is: What is a good tip speed for shaping a bowl blank? I did a little research and found several references to this simple formula: The diameter of the blank in inches multiplied by the lathe rpm should fall between 6,000 and 9,000. So, for example, you would want to turn a 10” blank somewhere between 600 and 900 rpm. A 5” blank should be turned at between 1,200 and 1,800 rpm, and so on. This video explains it: http://www.youtube.com/watch?v=-3mqZjTgVc4 -- Charlie M. "Woodworking - patience = firewood" |
#9 posted 1144 days ago |
I can answer the safest speed is 0.0 -- Cosmicturner |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15746 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
