What would cause a table saw to smoke?
Forum topic by Benzilla posted 05-04-2016 02:06 PM 6995 views 0 times favorited 20 replies Add to Favorites Watch
View Benzilla's profile
Benzilla
14 posts in 980 days
05-04-2016 02:06 PM
I have an older (1965) Unisaw, single phase 1.5hp running 115v that I bought last week. When I ran it before purchase it ran fine and cut a test as well as it could with the super dull blade, and the only smoke I noticed was from the cedar the dull blade burned through making the cross cut. I used it yesterday and it started fine, and ran fine, but I got about 3” into a rip cut and smoke started coming out from below the table top. The motor and blade didn’t seem effected by the cut, didn’t slow down or turn off or anything. I stopped the cut, turned off the motor, and took out the throat plate but could not see where the smoke was coming from. It didn’t smell like that ozone smell from a burnt motor. It didn’t have a rubber smell so I don’t think it was the belts. I just don’t know enough about the interworking’s to make even an estimated guess as to where to start. Does anyone know what that could be? Could the bushings burn, or could something underneath start some sawdust smoldering? There is no smoke unless the blade is cutting something.
Any help would be appreciated… any yes, I do realize I will see some jokes based on the title of this thread :)
Thanks guys!
-- -- Do as I say, not as I do --
20 replies so far
View waho6o9's profile
waho6o9
8523 posts in 2779 days
#1 posted 05-04-2016 02:07 PM
Maybe a capacitor?
View conifur's profile
conifur
955 posts in 1353 days
#2 posted 05-04-2016 02:31 PM
You did not mention if you installed a new or sharpened blade. I would think it is the blade. Is the wood burnt on the cut edge?
View jbay's profile
jbay
2882 posts in 1101 days
#3 posted 05-04-2016 02:38 PM
and yes, I do realize I will see some jokes based on the title of this thread :)
Thanks guys!
Late night out drinking?
Benzilla
#4 posted 05-04-2016 02:52 PM
I have not gotten a new blade yet, still trying to decide which to go with, and get the time to go to the store or just order one on-line. Yes, the wood gets the brown burnt marks on the cut end, but not enough to create the smoke I had yesterday and once I stopped the saw there was no smoke coming from the board, but from the throat plate it kept coming out for three to five minutes.
Waho6o9: I looked up the capacitor issue, and that may very well be it. From what I read on-line there are two capacitors on a motor, the starter and the running. How do I tell which is which on the motor so I know which one to remove and replace as I don’t have any problem starting the saw? Sorry I’m at work and don’t have it to look at in front of me, but from what I see on-line there are no labels on the covers saying which is which.
conifur
#5 posted 05-04-2016 03:20 PM
I bet its the blade, no ozone smell, burnt cuts, and only when cutting.
View splintergroup's profile
splintergroup
2429 posts in 1424 days
#6 posted 05-04-2016 03:36 PM
This happens often to me. Did the cut burn the edges of the wood? Does the smoke coming from the saw smell of burning wood? Chances are the sawdust created by the blade was burning as it fell into the saw cabinet. Any other sawdust down their also has the potential to start burning.
Big time fire hazard you need to watch out for.
View pintodeluxe's profile
pintodeluxe
5798 posts in 3015 days
#7 posted 05-04-2016 03:37 PM
Start with the blade. A Freud LU86 thin kerf, or a Diablo 1040x perhaps. Quite inexpensive blades for the performance they deliver.
View MrUnix's profile
MrUnix
7050 posts in 2401 days
#8 posted 05-04-2016 03:53 PM
To start off… did you do anything to the machine once you got it? Like check the belts, replace bearings, clean and lube, verify alignment, etc… ??
Capacitors can be tested with a simple multimeter in resistance mode. Google it.
With the amount of smoke you indicate, it should be fairly easy to determine it’s origin.
Let the magic smoke out of the motor, and you are looking at a major expense to replace.
Benzilla
#9 posted 05-04-2016 05:33 PM
I did not replace or adjust anything yet, the belts look good, and everything moves freely.
I’ll go get the Diablo 1040X tonight as the local HD have them for $30.
I’ll blow out everything I can reach, check the alignment, and try another cut and see what I get before starting down the capacitor road, but that seems like an easy fix too, so I’ll keep my fingers crossed its one of those two issues. Thanks everyone!
View bbc557ci's profile
bbc557ci
595 posts in 2276 days
#10 posted 05-04-2016 09:14 PM
As a test you could simply bolt on a known sharp 7 1/4 circular saw blade, and see if you still get the smoke.
Damn… It’s a little after 5 PM here in central NY, so you may have already hauled azz for HD ??
Let us know what gives after trying a new or sharp blade.
-- Bill, central NY...no where near the "big apple"
View Sawdust2012's profile
Sawdust2012
144 posts in 1914 days
#11 posted 05-04-2016 09:21 PM
Peer pressure?
View rwe2156's profile
rwe2156
3171 posts in 1683 days
#12 posted 05-04-2016 10:27 PM
Dude—if you already know the blade is dull get a new blade and then seek advice.
Is the wood burnt? That’d be a clue!
conifur
#13 posted 05-04-2016 10:34 PM
Is the wood burnt? That d be a clue!
- rwe2156
The wood is burnt, the blade is dull, it only smokes when cutting, and the smoke does not smell electrical.
These thread starters drive me nuts too.
View knotscott's profile
knotscott
8148 posts in 3577 days
#14 posted 05-04-2016 10:54 PM
My tires are bald, and the car is sliding when I drive on wet roads…. Any clues to why? ;-)
View jbay's profile
jbay
#15 posted 05-04-2016 10:55 PM
My car is sliding on wet pavement….the tires are bald. Any suggestions? ;-)
- knotscott
Wait until the road is dry? :>/
Are your tires on backwards?
