Undoing a liquid hide glue joint...don't use hot water
Forum topic by ppg677 posted 05-02-2016 03:25 AM 1007 views 0 times favorited 3 replies Add to Favorites Watch
View ppg677's profile
ppg677
209 posts in 1061 days
05-02-2016 03:25 AM
I started using Titebond Liquid Hide Glue because of my frequent mistakes.
Decided to undo a joint I wasn’t happy with. Googled…saw suggestion to use hot water. I poured about a half cup on the dovetail joint. Yeah, it came undone but the 7” wood now flares out 1/8” from wood expansion! That is, then 2” of wood near wear I poured is now 7 1/8” wide instead of 7”. Of course the dovetail no longer fits.
I tried oven at 200 degrees for a few hours. And it’s been 2 days. Still flared out. Makes me wonder if I permanently messed up the piece.
Heat gun next time??
3 replies so far
TopamaxSurvivor
18394 posts in 3881 days
#1 posted 05-02-2016 06:44 AM
Probably. If he doesn’t see this thread and advise, contact Paul
View Kaleb the Swede's profile
Kaleb the Swede
1876 posts in 2174 days
#2 posted 05-02-2016 10:31 AM
I think maybe you should have heated the glue with a heat gun and made it viscous again. And then it should pull apart. Water is normally for cleaning around the joint.
Paul would be the one to know definitely
-- Just trying to build something beautiful
View shipwright's profile (online now)
shipwright
8166 posts in 3003 days
#3 posted 05-02-2016 02:37 PM
To reverse hide glue requires both heat and moisture. Heat alone won’t do it once the joint has dried completely.
However, moisture means that the glue must be moistened, not that the whole area should be soaked.
Particularly if you are using a soft wood that has serious expansion issues it pays to start with a little water (hot wet rag), give it a little time, try it, repeat. You can add a little heat from a heat gun or an iron but take your time and try not to soak the whole area.
Hide glue is very strong and will not always give up easily. If the joint is deep it will require some time and patience to get the moisture into all of the glue.
In my experience expanded wood has always come back to original size eventually. My guess is that you have soaked deeper than you have dried.
