Incra ts-ls fence
Forum topic by Omar157 posted 05-02-2016 12:29 AM 809 views 0 times favorited 11 replies Add to Favorites Watch
View Omar157's profile
Omar157
55 posts in 886 days
05-02-2016 12:29 AM
Hey guys
I just purchased and installed the Incra ts-ls saw fence and I have a small issue. After squaring it up to the miter slot I used my woodpecker set up dial and it seems like I’m off 5 thousandths in the center. I am getting the same reading on both ends but as I move along the face I get the 5 thousandths difference. It starts about a 1/4 of the way and on the other side it zeros out about the same distance from the end . I guess I have to get Incra to send me new fence but I am curious how much will this affect my finish. I have a big project to finish by June 1st. And I can’t wait until I get the new fence to start it. Is 5 thousandths enough to be noticeable.
11 replies so far
View Woodknack's profile (online now)
Woodknack
12079 posts in 2435 days
#1 posted 05-02-2016 12:52 AM
Depends. What is the project?
View alittleoff's profile
alittleoff
540 posts in 1332 days
#2 posted 05-02-2016 01:54 AM
I put a peice of 3/4” maple on the front of my fence. It’s easy to do and if it’s off a little you can shim it.
Gerald
Omar157
#3 posted 05-02-2016 02:07 AM
Thats actually not a bad idea. I am building some flat panels to build 100lf of wall to hang art
Woodknack
#4 posted 05-02-2016 04:19 AM
LOL, you’re not going to notice .005” on partition walls.
View JeffP's profile
JeffP
573 posts in 1447 days
#5 posted 05-02-2016 11:04 AM
I agree, that a bowing in your fence of 5 thou will go completely unnoticed with almost any type of woodworking.
Another factor is that the primary value of the Incra accuracy is it’s repeatability. It sounds like what you have described would result in all of your pieces being “off” in the same way. Even if that 5 thou mattered, the fact that it is consistent would further lessen its impact.
I’m wondering if you have done anything to verify that the miter slot is not the source of (some or all) of your error in the measurement?
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
Omar157
#6 posted 05-03-2016 10:14 PM
Thanks guys. I called incra and they said .5 is pretty much the best I will get. After final setup it was actually.10 so they are going to replace it for me. Mark at incra is awesome. Thanks again
View Paul's profile
Paul
721 posts in 1620 days
#7 posted 05-03-2016 10:51 PM
- Omar157
Are you sure it was mark and not MadMark?
View AZWoody's profile
AZWoody
1352 posts in 1279 days
#8 posted 05-03-2016 10:57 PM
- Omar157
- Paul
I think the odds of them being 1 and the same is high.
Woodknack
#9 posted 05-04-2016 12:08 AM
- Paul
Mystery solved.
JeffP
#10 posted 05-04-2016 10:20 AM
I have never seen them both in the same room at the same time…
hmmmm, come to think of it, I have never seen EITHER of them in the same room at the same time.
the mystery deepens…
Omar157
#11 posted 05-04-2016 11:17 AM
I don’t know the difference between the two but if you ever watch the Incra YouTube videos that’s who I spoke with. He way very helpful and honest to God knew his shet. I had my system running whisper quiet within a few min on the phone which is something I played with for an hour before I called.
