If a tree falls in the forest...
« back to Coffee Lounge forum
Forum topic by SST posted 03-29-2010 05:46 AM 1998 views 0 times favorited 7 replies Add to Favorites Watch
View SST's profile
SST
790 posts in 4436 days
03-29-2010 05:46 AM
Topic tags/keywords: humor
If a tree falls in the forest and lands on your head…does it make a sound just before the lights go out???
-- Accuracy is not in your power tool, it's in you
7 replies so far
TopamaxSurvivor
18428 posts in 3917 days
#1 posted 03-29-2010 06:08 AM
Here in Water World, aka: Western WA, the trees are so thick you would hear the cracking of many branches before the lights went out. You may still not have time to react : -((
View SwedishIron's profile
SwedishIron
142 posts in 3882 days
#2 posted 03-29-2010 07:55 AM
TopamaxSurvivor,
My parents took this picture last week while driving up the Washington coast towards La Push.. I think this is one of those little giants that make up the Thick forests in those parts. Nice piece of drift wood.. :)
Wee little piece of Washington state driftwood
-- Scott, Colorado
TopamaxSurvivor
#3 posted 03-29-2010 08:00 AM
Yeah, that looks about right. The Olympic Peninsula is full of 200 foot firs. They are big, but not quite like the redwoods ;-)
When I flew my grandmother out here from Iowa for her oldest grandchild’s high school graduation, my son; she could not believe the trees and water everywhere! In Iowa, if you get tired of looking at corn, you can look at either soybeans or hogs ;-))
View Napaman's profile
Napaman
5530 posts in 4318 days
#4 posted 03-29-2010 06:25 PM
i went up the Hoh River trail…one of the most beautiful backpacking trips I have been on…
i say you do hear it…the brain is faster then anything…the trick is…is it fast enough to signal then move your bum out of the way…no likelly…
-- Matt--Proud LJ since 2007
View Gene Howe's profile
Gene Howe
11167 posts in 3669 days
#5 posted 03-29-2010 06:33 PM
Topmax,
and/or silos.
13641 posts in 3582 days
#6 posted 03-29-2010 06:46 PM
i worked for 6 moths making access roads for the forest guys in the sierras .
the logging company i worked for got all the trees , 6 and 8 foot trunks .
when they had to dynamite the stumps ,
we got a warning .
hide behind the biggest tree around .
wait for 30 seconds ,
and you could hear the rocks falling down through the branches ,
it gave you just enough time to clear out if they were overhead !
TopamaxSurvivor
#7 posted 03-30-2010 05:57 AM
When I was about 15 or 16, little bro (LB) and I were helping one of our uncles pick rock off his field. There were some big ones that we had to blow apart, too big to move. Unc decided to go to town. He left me in charge. Gave me some blasting caps, fuse, book of matches and box of dynamite. Needless to say, most of the rocks were too big for us to move, so we blew them all to smithereens!! Our mother would have killed him if she had known what we were doing ;-))
One day we were blowing rock. Unc had lit a fuse and we all took off. After a few minutes, LB and I knew it should have gone off by now. Pretty soon, Unc asked if one of us wanted to go look in that hole and see what was going on? Neither of us thought we wanted to go. ;-)) After a few more minutes, Unc decided he’d go check it out. He headed toward the hole, but about half way there he started circling. He ended up approaching from the far side. He was tippy toeing, trying not to jar the ground I guess, just like the Sylvester used to do sneaking up on Tweety Bird. When he finally got there, he stepped down into the hole and relit the fuse.
Another day, a lava rock about the size of a basket ball flew at least a couple hundred feet almost straight up in the air. Unc and I had run down and hid behind his pickup truck. LB had run for the old Oliver tractor. As the rock started down, it was headed straight for the Oliver and LB! LB took off as hard as he could go! Unc said, “ s%& fire!! That rock is going to land right on the Oliver!” We heard it clank on metal as it hit. We went over to access the damage. The rock was laying right at the back of the Oliver between the tires. We couldn’t see any damage at all. It must have just hit the end of the draw bar and made the sound we heard. Luck break for Unc that time ;-))
