Pistol Silhouettes
Forum topic by Gene Howe posted 1152 days ago 682 views 0 times favorited 7 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
3197 posts in 1599 days
1152 days ago
Does anyone know where I can find exact silhouettes of different models of pistols?
I make presentation boxes and must have the piece in my shop until the boxes are finished. Many guys don’t want to part with “Betsy” for that long.
Thanks to you all.
Gene
7 replies so far
View antmjr's profile
antmjr
256 posts in 1354 days
#1 posted 1152 days ago
why don’t you draw the silhouette by yourself? you can get the silhouette magnified by the offset of the pencil (actually half diameter of the pencil), that’s to say what you need if you will use a router with the right template follower. If I did something similar, I’d fix the pistol on the paper by means of some plasticine, 2-3 points, and then I’d draw the siluette carefully.
hope my answer isn’t completely idiot :-)
-- Antonio
View jussdandy's profile
jussdandy
157 posts in 1377 days
#2 posted 1152 days ago
check into a blue gun, it is a plastic non firing gun that you can practice with without using a real gun, home defence courses use them a lot,I belive they have a lot of diffrent ones.
-- Randy I have the right to remain silent, just not the ability ; )
View BrianA's profile
BrianA
46 posts in 1200 days
#3 posted 1152 days ago
How about scanning it Or photo copy?
Brian
View UnionLabel's profile
UnionLabel
660 posts in 1370 days
#4 posted 1151 days ago
Gene, here you go. http://www.clipartlab.com/pdf_bitmap/clipartlab_guns_bitmap.pdf
-- Methods are many,Principles are few.Methods change often,Principles never do.
Gene Howe
#5 posted 1151 days ago
Thanks everyone, for all your good suggestions.
Looks like I’ll be tracing them.
Gene
View LeeG's profile
LeeG
40 posts in 1191 days
#6 posted 1151 days ago
Take a photo with a good camera from directly above with a ruler laying flat on top of the gun. Resize the image until the ruler is 1:1 size and print.
-- Lee in Phoenix
Gene Howe
#7 posted 1151 days ago
Thanks, Lee.
I’ll give that a shot, also.
