Marblewood, cracking
Forum topic by Dukegijoe posted 03-28-2010 03:00 PM 1307 views 0 times favorited 1 reply Add to Favorites Watch
View Dukegijoe's profile
Dukegijoe
55 posts in 3013 days
03-28-2010 03:00 PM
Okay, so I made a Jobillo bandsaw box from a turning blank, which I posted last night. My second attempt was a box made from Marblewood, but my wife called me away from the box about midway through. I didn’t think this would be a big deal, but coming back the next day, i found cracks (almost clean all the way through) in the 1/2 in top and bottom, as well as across the walls of the box. Has anyone else worked with Marblewood? What techniques can I use to reduce cracking? btw, I am located in Houston, TX with a lot of humidity, and the wood block starts with a wax coating (which probably doesn’t allow the wood to acclimate very well). Thanks.
-- Anybody can become a woodworker, but only a Craftsmen can hide his mistakes! - Walter Blodgett
1 reply so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3676 days
#1 posted 02-24-2017 11:13 PM
—————Ancient Post———-Clearing it from the zero answered forums list———-
Yeah the wood was probably not at equilibrium when you cut it so it lost a lot of moisture very quickly causing the cracking. Acclimatizing small pieces must be a bit of an art as the surface area to moisture content is pretty high.
