Diamond plate vs water stones
« back to Hand Tools forum
Forum topic by Ray posted 04-30-2016 01:58 AM 1443 views 0 times favorited 9 replies Add to Favorites Watch
View Ray's profile
Ray
126 posts in 2054 days
04-30-2016 01:58 AM
I see posts where forum members are now using diamond plates for honing. But the grit numbers have me confused. What is the equivalent of a 1200 diamond plate in a conventional waterstone?
Thanks
-- Creating less fire wood every day
9 replies so far
View lateralus819's profile
lateralus819
2241 posts in 1941 days
#1 posted 04-30-2016 02:35 AM
An extra fine DMT Plate is about 1200 grit and an extra extra fine is about 8000 grit.
View Lumberpunk's profile
Lumberpunk
334 posts in 2388 days
#2 posted 04-30-2016 02:44 AM
I have Coarse, Medium and Fine DMT plates and then switch to a Norton 8000 grit water stone for the microbevel. Fast and sharp. The coarse stone is only for reconditioning damaged irons and flattening the Norton when it needs it.
-- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life.
View TheFridge's profile
TheFridge
9700 posts in 1537 days
#3 posted 04-30-2016 03:11 AM
Depends on the stone. Stones can be a lot finer than diamond particles. Also depends on particle size.
View Ray's profile
Ray
#4 posted 04-30-2016 03:25 AM
Am I correct in understanding from these posts that the grit designation is somewhat equal between diamond and waterstone?
View rwe2156's profile
rwe2156
2997 posts in 1532 days
#5 posted 04-30-2016 12:33 PM
It is quite confusing.
Grit sizes for water stones, diamond stones, and sandpaper are all different.
Somewhere I saw a chart that compared them.
My impression is water stone grits tend to be finer than diamond. I have 8000 grit in both diamond and water and no question the waterstone is much finer.
View HokieKen's profile (online now)
HokieKen
5569 posts in 1190 days
#6 posted 05-01-2016 01:22 AM
Here is a pretty comprehensive chart from knifeforums.com
-- Kenny, SW VA, Go Hokies!!!
View bbasiaga's profile
bbasiaga
1236 posts in 2046 days
#7 posted 05-01-2016 03:14 AM
Another chart I refer to often.
http://www.razorandstone.com/attachment.php?s=3195b77d98585eb80b3fa932ba16ecc3&attachmentid=1939&d=1352583847
I just ordered a fine DMT stone, to do my primary sharpening. Then plan to finish with a 4k/8k water stone.
-Brian
View Andre's profile
Andre
1921 posts in 1857 days
#8 posted 05-01-2016 03:28 AM
Only thing Diamond stones are good for are to Flatten my Water Stones! LOL!
TheFridge
#9 posted 05-01-2016 03:44 AM
I use diamond stones for flattening. I don’t find they take a lot of material off after break in but they are a good reference for me. I use paper for sharpening but will prob get some Shapton water stones after trying them out. They took off material fast and honed gorgeously.
I’ve found similar grits in paper and water/oil stones finer than diamond.
