Multiple Blades on Table Saw
Forum topic by Deela40 posted 04-29-2016 03:51 PM 2316 views 0 times favorited 21 replies Add to Favorites Watch
View Deela40's profile
Deela40
108 posts in 3289 days
04-29-2016 03:51 PM
Topic tags/keywords: question tablesaw
Has anyone ever done multiple blades on a table saw with spacres between the blades? I am not talking about a dado stack, but need to cut three separate grooves as shown on the right:
There is about 5/32” between the grooves. I make and sell clothespins and am currently making three passes to make these grip gorrves. I am looking to cut down on production time, so I was wondering if it was safe to put two blades on my saw with spacers on between.
-- www.heritageclothespins.com
21 replies so far
View Clarkie's profile
Clarkie
466 posts in 2042 days
#1 posted 04-29-2016 04:00 PM
Think about it, have you ever seen it advertised, “You can use 2 or 3 blades at one time on our table saw”. Seriously, I’d say no to the idea, the arbor isn’t designed for that. You may get away with it, but then again you may not, and it’s the “may not” side you don’t want to be on. I almost lost my thumb on a tablesaw a little while back, I can only imagine what may go wrong with trying what you are asking. Be safe, not always necessary to speed up production.
Deela40
#2 posted 04-29-2016 04:12 PM
Thank you Clarkie. I was leaning against doing it, but wanted to verify. I found a good bit about using multiple blades as a dado stack, but could not find any discussion about using two blades that are farther apart.
View BenjaminNY's profile
BenjaminNY
134 posts in 1603 days
#3 posted 04-29-2016 04:30 PM
They make machines that gang rip/score etc. I would not ad hoc it on a machine not designed for that application. It may work but it’s too risky.
View ClammyBallz's profile
ClammyBallz
449 posts in 1337 days
#4 posted 04-29-2016 05:01 PM
What if you ground down the teeth on two of the chippers and used them as spacers? They would have to be perfectly balanced though.
View jumbojack's profile
jumbojack
1685 posts in 2825 days
#5 posted 04-29-2016 05:28 PM
I would try it…...maybe. I think I would be more inclined to use spacers against the fence. Although in a production run you could groove a few boards and have a bunch of clothes pin blanks in no time.
View pintodeluxe's profile
pintodeluxe
5798 posts in 3014 days
#6 posted 04-29-2016 05:50 PM
(5/32” space x 2) + (1/8” kerf x 3) = .6875”
Most arbors can accept a 13/16” dado stack, so I don’t see why you couldn’t.
Those shallow grooves won’t tax most tablesaws. Some woodworkers use double blades to cut tenons, so his isn’t much different. Fender washers would make ideal spacers (5/8” I.D. for 5/8” arbor).
I would use the two outer blades of a dado stack, and one chipper in the middle.
View MrRon's profile
MrRon
5193 posts in 3444 days
#7 posted 04-29-2016 06:23 PM
The only thing I can see that could be a problem is; a change in blade spacing through vibration which might cause the work to bind resulting in uneven thickness and possible kick back. Maybe using smaller diameter blades would work. What you are doing is a job for a shaper or a planer/molder.
MrRon
#8 posted 04-29-2016 06:23 PM
Duplicate post
View splintergroup's profile
splintergroup
2429 posts in 1423 days
#9 posted 04-29-2016 06:26 PM
I also don’t see any real issues. Dado set parts will work, but most outer dado blades have beveled grind teeth which would not give a very flat bottom cut. I think better results could come with a gang of three flat tooth rip blades.
Also consider that most large dado stacks are 8”, not the normal 10” of a table saw. Although a typical 8” dado stack has greater rotational inertia than three 10” blades, you could/should stick to 8” (or more popular 7-3/4”) blades (cheaper as well!).
View SirIrb's profile
SirIrb
1239 posts in 1431 days
#10 posted 04-29-2016 06:42 PM
use steel spacers and keep the digits out of them and youll be fine. I would say that the reason you haven’t seen saws advertised for that is because there arent too many people making clothes pins or need to score in that method, not because it is unsafe. I wouldnt rip through the board with a stack, though this is doable: google Gang saw.
go get em
Deela40
#11 posted 04-29-2016 07:46 PM
Thanks for all the feedback thus far. I may try these blades and see how it works.
View JohnDon's profile
JohnDon
66 posts in 1370 days
#12 posted 04-29-2016 08:01 PM
As an alternative to using washers as spacers, you might try using CD’s. They conveniently have 5/8” center holes, are dead flat (washers might have burrs and deflections from the stamping), and they have a lot of surface area to bear against the blades, so they will more likely to stay parallel and not wobble. With the shallow grooves you’re making, they wouldn’t interfere with the cut, even with 7-1/4” blades. If they don’t give you exactly the right distance between the blades, you can use them as patterns to cut shims from paper or thin cardboard.
View knotscott's profile
knotscott
8147 posts in 3576 days
#13 posted 04-29-2016 08:06 PM
- Deela40
I don’t see why it couldn’t work if your saw has the arbor length and the power. I do think you can do a lot better than those Irwin Classic blades though…you can get Freud Diablo 24T blades for the same price, or the 40T for another $5 ea…..much better blades.
splintergroup
#14 posted 04-29-2016 08:36 PM
Watch out for circular saw blades, they usually are thin kerf, i.e. much less than 1/8” wide (if that is your target groove width). Also look for FTG (flat top grind) if you want flat bottomed grooves.
Alternatively you could use a single FTG rip blade and make up a set of spacers (or even carriers) you place between the workpiece and the table saw fence. This would require a pass for each groove, but there would be no extra setup or fence moves, just make a pass, switch to the next carrier, another pass, rinse, repeat.
Deela40
#15 posted 04-29-2016 08:49 PM
I don t see what it couldn t work if your saw has the arbor length and the power. I do think you can do a lot better than those Irwin Classic blades though…you can get Freud Diablo 24T blades for the same price, or the 40T for another $5 ea…..much better blades.
- knotscott
I will check out the Diablo blades. I was just looking for some cheap ones see if it worked.
