how far to sharpen various tools?
« back to Hand Tools forum
Forum topic by bbasiaga posted 04-29-2016 01:50 PM 1094 views 0 times favorited 19 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1118 posts in 1898 days
04-29-2016 01:50 PM
Topic tags/keywords: sharpening
I just got a plane with a wider blade, which of course meant I needed a new sharpening stone. I got to reading around, and thought it would be interesting to see what other LJs are doing with their sharpening practice.
Regardless of what you use – diamond stones, water stones, sandpaper – how far do you take it? 4000 grit? 8000grit?
Do you sharpen all your tools to the same level? Or do you stop at lower grit for rough applications? For example, do you take your jack plane to 4k grit, but your smoother to 8k? Your rough chisels to 1k or 2k, but a paring chisel to 6 or 8k?
Here to fore, I had a only a 1k/6k water stone. So that’s how I sharpened everything. Now I’ll have 4 and 8 k as additional options.
Brian
19 replies so far
View mds2's profile
mds2
310 posts in 1847 days
#1 posted 04-29-2016 02:03 PM
I go to the highest stone I have, then strope with polishing compound. I have a full set of norton waterstones 220 through 8000 grit. I used to go through them all. Now I use DMT plates. XFine is the highest grit I have which is like 1200 grit.
View waho6o9's profile
waho6o9
8099 posts in 2480 days
#2 posted 04-29-2016 02:11 PM
DMTs
8000 Japanese water stone with Nagura stone ( to make a slurry )
Then strop with green compound from Lee Valley
Sometimes .something micron PSA paper is used.
https://www.toolsforworkingwood.com/store/dept/THS/item/ST-MAF.XX
The sample packet is a good starting kit :)
View Bob5103's profile
Bob5103
86 posts in 737 days
#3 posted 04-29-2016 02:26 PM
Depends…I prefer oil stones, but if I am repairing/reshaping a blade or iron I start with DMT diamond stones, extra coarse through extra fine. Normal touch up or sharpening I work through a soft Arkansas to a surgical black. Or somewhere in between. I always finish on either a 6k or 8k water stone and then strop. I know it’s kinda weird, but I like to make hunting knives in my “spare” time and this is what works for me. Here is my sharpening station.
View Richard H's profile
Richard H
489 posts in 1584 days
#4 posted 04-29-2016 02:29 PM
You don’t absolutely need new stones for a larger iron. Work the edge on the stone in small circles over the entire surface of the stone and let it hang off the edge. I assume you will be cambering the iron anyways so you really never work on more than a portion of the iron at a time regardless. A bigger stone is a luxury for sure but it’s also a larger surface area to have to keep flat.
I have 1k, 4k and 8k stones and while I don’t consider a 1k edge honed either 4k or 8k seems to work fine especially if you strop the edge afterwards.
View OSU55's profile
OSU55
1515 posts in 1893 days
#5 posted 04-29-2016 02:32 PM
For smoothing, jointing, shoulder, block, shave blades up to ~12,000 (0.3 um). 4,000 is probably high enough for scrub/jack planes. If interested here’s how I hone.
View Don W's profile
Don W
18604 posts in 2471 days
#6 posted 05-04-2016 12:17 AM
I sharpen everything on a 2” stone. Turn it semi sideways and use a Z pattern.
I sharpen everything to sharp. All on a hard Arkansas stone.
View jmartel's profile
jmartel
7687 posts in 2053 days
#7 posted 05-04-2016 12:46 AM
As was said, you don’t necessarily need wider stones. Just skew the blade. And I go up to 13000 grit.
bbasiaga
#8 posted 05-04-2016 02:02 AM
Hi. My name is Brian. I cannot sharpen anything by hand. I’m really good at making things dull, unless I have a honing guide. With that, I can overhang the stone, but the skew method doesn’t work so well.
Brian
View rwe2156's profile
rwe2156
2796 posts in 1384 days
#9 posted 05-04-2016 12:05 PM
<quote>Hi. My name is Brian. I cannot sharpen anything by hand. I’m really good at making things dull, unless I have a honing guide. With that, I can overhang the stone, but the skew method doesn’t work so well.
BrianBrian, that sounds like a “sharpeners anonymous” intro (LOL).
What specifically is your difficulty? Perhaps I can help you.
I go to 8000 + strop with just about everything. Your 6K would work fine, too.
One poster mentioned sharpening to 3000. IMO that is not enough, particularly if dealing with planing obstreporous grain. I’ve seen Paul Seller’s “sharpening to 600” video and quite honestly that would never work for me I don’t even consider that sharp! Its a matter of personal choice, what kind of tools you have and what type of wood you are using.
The grits on diamond stones, water stones and sandpaper are all different. My impression is water and diamond of the same grit the water will be a bit finer.
I think you could get by with 2” stones. I have only 3 and 4” wide stones but actually I skew the blade anyway because ergonomically that’s the way my sharpening technique has evolved.
I think skewing the blade just a bit increases accuracy, but your experience may be different.
Couple hints on technique: lock your elbows and rock your body & flatten the water stones before EACH use.
bbasiaga
#10 posted 05-04-2016 01:33 PM
I could definitely start Sharpeners anonymous. I guess I just don’t have a steady enough hand to keep a consistent angle and get a good edge. So I use the Veritas honing guide. Works good for me, but has some limits.
Brian
Richard H
#11 posted 05-04-2016 01:55 PM
I had a hard time with freehand sharpening as well until someone showed me that you don’t sharpen with your arms you sharpening with your body moving and your arms locked to your side. Once I started to work this way I found holding a consistent angle was a lot easier.
The one thing I don’t do is put a micro bevel on my tools anymore. Since I started to hollow grind my tools there doesn’t seem to be any advantage to do that since the iron is only touching the stone at the tip and heel anyways and because it touches in two points it’s a lot easier to find the same bevel angle when I go back to touch up a edge.
Shanon over at the The Renaissance Woodworker has some great videos on this technique of body movement such as this one here. http://www.renaissancewoodworker.com/rww-171-free-hand-sharpening/
He didn’t invent it but the way he explained it seems to work well for me.
I have a huge issue with putting cambers on irons with guides and I have tried several different kinds. It’s not impossible but I have never been able to get good consistent results when using guides so for any thing except chisels guides seems like more trouble than they are worth for honing. And even than honing most chisels by hand is just faster once you get the hang of it. Now for taking a nick out of edge I think guides make the whole process a lot easier and faster since you are removing steel very evenly.
Hope this helps and good luck,
Richard
View HokieKen's profile
HokieKen
4611 posts in 1042 days
#12 posted 05-04-2016 06:38 PM
I could definitely start Sharpeners anonymous. I guess I just don t have a steady enough hand to keep a consistent angle and get a good edge. So I use the Veritas honing guide. Works good for me, but has some limits.
Brian
- bbasiaga
I can hone my chisels freehand all day long. But, for some reason I just can’t get it down with plane irons. I guess it’s the thin blades and my fat “sausage” fingers :P If you recess a pocket into a sheet of MDF so you can put your stones in the pocket with the top of the plate flush with the surface, you can turn your stone 90 degrees and hone in that direction and still use the guide.
-- Kenny, SW VA, Go Hokies!!!
rwe2156
#13 posted 05-05-2016 12:02 PM
Brian lots of great ww’ers use honing jigs. It will definitely keep your blades at a consistent angle.
One problem I have is the angle will gradually creep up because I tend to increase the angle just a tad with each sharpening (probably just impatience wanting to get the burr more quickly to get back to work). I’ve had chisels get almost to 40 degrees. When this happens I just redo the hollow grind, usually about once a year.
I do use a jig every now and then to re-establish the bevel angle. I also use it on a couple chisels with 20 degree bevels for soft wood that I find a little difficult to hand hone.
View brtech's profile
brtech
1017 posts in 2826 days
#14 posted 05-05-2016 03:30 PM
Don’t forget that “grit” and “microns” and the other ways to measure sharpening surfaces vary a lot, mostly by the technology and sometimes by the vendor. “8000” isn’t always “8000”
View KayBee's profile
KayBee
1083 posts in 3149 days
#15 posted 05-06-2016 02:44 AM
Here’s a chart that might help. It’s the link(in the link) to a pdf that lists and compares most all types off sharpening stones, papers, powders, microns, grit and magic fairy dust.
blog.lostartpress.com/2014/09/08/true-grit-ii-a-chart-for-deciphering-sharpening-gear/
-- Karen - a little bit of stupid goes a long way
