Wood End to Flat Metal Joint Questions
« back to Joinery forum
Forum topic by Wondermutt posted 04-29-2016 01:32 PM 502 views 0 times favorited 3 replies Add to Favorites Watch
View Wondermutt's profile
Wondermutt
69 posts in 912 days
04-29-2016 01:32 PM
Hello, I am trying to join the end or edge of a sheet of plywood to a flat side of sheet metal with ho-hum results. I can not use mechanical fastners and this project will require the use of a liquid base bonding agent of some sort.
I will only have one shot at doing this again, so your suggestions are greatly appreciated. I have a small test piece now to try various adhesives before I commit to the final glue up.
The joint is not load bearing and will have to support a chunk of 3/4” plywood, 2 ’ x 3’. The sheet metal is typical flat mild steel, 12 gauge.
What would you use?
Thanks
3 replies so far
View JayT's profile
JayT
5731 posts in 2267 days
#1 posted 04-29-2016 01:47 PM
My first choice would be epoxy. Polyurethane glue might work, as well.
View SirIrb's profile
SirIrb
1239 posts in 1286 days
#2 posted 04-29-2016 02:01 PM
LIQUID NAIL
CONTACT CEMENT
YES, EPOXY.
View tomsteve's profile
tomsteve
796 posts in 1275 days
#3 posted 04-29-2016 02:11 PM
