Ladder/steps in oak, plank dimensions?
Forum topic by nebulous posted 03-27-2010 11:44 AM 1301 views 0 times favorited 2 replies Add to Favorites Watch
View nebulous's profile
nebulous
53 posts in 3096 days
03-27-2010 11:44 AM
I want to build a ladder/stair to the attic in my apartment. The hatch is too small for a standard fold-out ladder, so I’m thinking of attaching a solid pull-out ladder to the wall directly beneath the hatch. The angle will make it between a ladder and a staircase, and I want to have steps rather than rungs.
The width of the steps would be about 50cm (1 2/3’), depth 5 – 8 cm (2-3”). If I made the steps out of oak, what thickness could I expect to get away with?
Are there calculators for this online that I am just not finding?
2 replies so far
View Michael Murphy's profile
Michael Murphy
453 posts in 2973 days
#1 posted 03-29-2010 08:14 PM
1 2/3’ would be about 21 inches. In oak you could probably get away with 4/4 (1”) surfaced to 7/8” since the pieces are narrow and that short. Cut the rough material oversized a bit and joint and plane. Make sure the grain isn’t too wild and there aren’t any knots. Probably depends on the weight limit you are looking for.
Take a piece of 3/4 oak 24” long and put it up on a block at each end and stand on it. If it flexes more than you want, go thicker.
Starting with 5/4 and surfacing or gluing up two pieces of thinner stock and surfacing that down to 1” might be better. I assume you are going to dado the treads into the rails for support.
-- Michael Murphy, Woodland, CA.
3809 posts in 3990 days
#2 posted 03-29-2010 08:54 PM
I was sitting there doing this myself so I spent a bit of time checking out some rough lumber to see what can be done.
I find that the rough lumber in my area is not actually 4/4, it’s more like 15/16 inches. By the time you take the warp or wobble off this dimension of lumber is almost impossible to get 3/4 inch stock from it.
I’ve decided that I’ll go for 5/4 when I can find it.
I’m planning a mobile latter much like a library ladder for my shop so I’m looking for a full finished four-inch width for the rails and a full four-inch width for the stair treads. I plan to dado stair into the rails and reinforce the unit with quarter inch rod under each stair. I might be able to go lighter than this but I’m fairly hefty myself and toting a box of 50 or 60 pounds down that ladder is stretching the limits of lighter lumber.
Good luck with yours,
