Candy Cart
Forum topic by taraking posted 04-28-2016 01:14 PM 988 views 0 times favorited 13 replies Add to Favorites Watch
View taraking's profile
taraking
10 posts in 907 days
04-28-2016 01:14 PM
Hi,I’m a newbie! Looking for help to build a Candy Cart for my daughter’s wedding. I have no building skills at all!!! so looking for major help here please. Any help would be much appreciated.TIA
13 replies so far
View ChrisK's profile
ChrisK
2002 posts in 3230 days
#1 posted 04-28-2016 02:04 PM
A few sheets of 1/2” Birch Plywood, some 1×4 or 2×4, wood dowels for axles, fabric, paint, glue, screws, a circular saw, jigsaw ,drill and a compass to layout wheels. Decorate in the color of the wedding.
Not a first time project unless you have a few months. Look around your local area for wood workers guilds or craft guilds. The local woodworkers store is a good place to ask. Does your local highschool or trade school have a wood shop. I am sure a student would not mind making some money to build one.
-- Chris K
View HokieKen's profile
HokieKen
6298 posts in 1287 days
#2 posted 04-28-2016 05:18 PM
I imagine you’ll be wanting to hire the job out if you have no experience. If you post your location and some pics and/or links to something along the lines of what you’re looking for, you may get better response. Best of luck and welcome to the site!
-- Kenny, SW VA, Go Hokies!!!
taraking
#3 posted 04-28-2016 05:53 PM
Thanks so much Kenny & Chris for your reply.I’m kinda hoping to do it myself….ok except for the wheels,was thinking along the lines of bicycle wheels?? Chris your photo looks great! I Love it but maybe a bit advanced! Wood shop say they will cut the wood for me but they want a cutting list…..which is where I’m stuck,pic I’m showing looks doable :) Greetings to you both from Ireland!
https://s3.amazonaws.com/vs-lumberjocks.com/o6cuxpw.jpg!
ChrisK
#4 posted 04-28-2016 05:58 PM
Can you use sketch up?
The cart is pretty simple. No drawers maybe shelves on the far side.
Wheels can be cut with jig saw out of a piece of plywood.
-- Chris K
taraking
#5 posted 04-28-2016 06:30 PM
MMmmm No Chris don’t know how to use sketch up…..
ChrisK
#6 posted 04-28-2016 06:32 PM
I sent a PM to you. How soon do you need this? I might be able to get a cut list in a couple of weeks. Do you want more like I pictured or what you found? What you found would be pretty easy to build. What are the over all dimensions? I would still cut the wheels from plywood or a 1X glued up.
-- Chris K
taraking
#7 posted 04-28-2016 07:14 PM
I replied your PM Chris *Smiles
taraking
#8 posted 04-28-2016 07:36 PM
ChrisK I am so thankful for all your help…thank you so much.
HokieKen
#9 posted 04-29-2016 02:25 AM
Looks like Chris stepped up for you :). Hope it works out well for ya! Be sure to give us some pics when you get it done.
taraking
#10 posted 04-29-2016 09:53 AM
Hey Kenny,Yes Chris was very helpful, but I’m feeling a bit dejected this morning…I just can’t get a handle on the cutting list. For example,how do I get it to collapse for easy transport.? Could I use stair spindles for the canapoy part? what size should the cart actually be?
Should I make a frame first & then add sides….?
I have tried to get someone to make it for me,but am told the job is too small :(
as the song goes ’’I think I’d better think it out again’’ smiles
ChrisK
#11 posted 04-29-2016 12:14 PM
Good day,
You should be able to use stair spindles. Screw the spindles to the top and the bottom so you can take it apart to travel. Use at least 2 screws in each end so it will not rotate. If you can use carriage bolts it will be stronger, but you will need to drill through the 2 parts being attached and it may not look as good as a screw.
I use deck screws here for these types of things. You can use the side skirt of the candy area to screw the spindle to.
I would start looking at 700mm wide by 950mm long, make the areas that will be for the candy trays about 860mm from the floor.
What have you found for wheels?
-- Chris K
taraking
#12 posted 04-29-2016 06:49 PM
Found nothing on the wheels Chris.I tried a few bicycle shops today asking if they had anything,but they want me to buy the whole bike lol…..I’m trying to keep costs down,so I will keep looking!
I also went back to the wood shop,& if I’m honest they really weren’t very helpful,told me they were too busy to look at the photo & calculate what was needed,so all in all I’m back to sq 1…long weekend here in Ireland,so I wont make any headway until Tuesday at the earliest
View Texcaster's profile
Texcaster
1287 posts in 1822 days
#13 posted 04-29-2016 09:52 PM
Try contacting a local cycling club for wheels, those people go through wheels at an alarming (to them) rate.
-- Mama calls me Texcaster but my real name is Mr. Earl.
