FF Biscuits for Biscuit Joiner ?
Forum topic by Gary Lundgren posted 04-27-2016 06:52 PM 672 views 0 times favorited 8 replies Add to Favorites Watch
View Gary Lundgren's profile
Gary Lundgren
80 posts in 1362 days
04-27-2016 06:52 PM
Topic tags/keywords: biscuit joiner plate ff biscuits biscuit joiner
Just got A P*C biscuit joiner. I’m a newbie to this tool.
I understand that the FF biscuits are used on small pieces, such as face frames. From what I can tell, you can’t really use a biscuit joiner on stock that is less than 3/4 thick. Is that correct? So your face frames would be made of 3/4 thick material?
That 2” blade is quite pricey at about $60. Any better sources for that?
Thanks! Gary
-- GaryLundgrenCrafts
8 replies so far
View HokieKen's profile
HokieKen
4594 posts in 1008 days
#1 posted 04-27-2016 07:16 PM
I’ve never used a PC but on my Freud, you can adjust the fence for different stock thicknesses then register the fence on top of the material. If you register the base of the joiner and the material off the same surface instead of using the fence, it cuts a slot centered on 3/4” material.
-- Kenny, SW VA, Go Hokies!!!
View lew's profile
lew
11888 posts in 3625 days
#2 posted 04-27-2016 07:18 PM
I have one of the original Porter Cable biscuit joiners (thanks to “norm”)
I use the stock cutter and the smallest biscuit I use is the #0. The cutter makes a 1/8” kerf (I think). I’ve used it on material as thin as 3/8” with no problems.
View teejk02's profile
teejk02
479 posts in 995 days
#3 posted 04-27-2016 07:20 PM
My PC 557 came with all the parts required to use the FF biscuits (including the blade but not including the biscuits). Never used it though. I use the Kreg for face frames.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2401 days
#4 posted 04-27-2016 07:31 PM
Your 557 should come with a clear plastic spacer that clips to the underside of the fence. This allows the jointer to work with stock thinner than 3/4”
-- Mark Kornell, Kornell Wood Design
4823 posts in 2363 days
#5 posted 04-27-2016 07:38 PM
It will work with smaller stock, you need the plastic piece that Mark Mentioned. I’ve never seen any aftermarket blades for the FF biscuits, though the full size aftermarket cutters are available. If there is an aftermarket FF cutter, I’d be interested in one as well.
Gary Lundgren
#6 posted 04-27-2016 07:51 PM
Thanks everyone for all the great info! Guess I need to read manual on that plastic piece. Didn’t seem to find anything on YouTube.
Thanks! Gary
View Rick_M's profile
Rick_M
10811 posts in 2250 days
#7 posted 04-28-2016 12:22 AM
Yes, you can use it on less than 3/4 stock. FF biscuits are dinky. I had a pack of them for 15 or so years and never found a use for them so gave them away. #10 is the most common size I use followed by #20.
-- http://thewoodknack.blogspot.com/
View pintodeluxe's profile
pintodeluxe
5542 posts in 2683 days
#8 posted 04-28-2016 12:29 AM
I think FF biscuits are too small to be useful. I assemble face frames with pocket screws, then use the #20 biscuits to attach the frame to the cabinet. Works great.
In applications where the top of the frame is hidden, you can use #0 biscuits and trim off the excess. In cases where you have 2” wide rails and stiles, #0 biscuits will actually fit with careful layout (they are 1.75” long).
