X-Y Compound table for a wood lathe
« back to Woodturning forum
Forum topic by moke posted 04-27-2016 05:27 PM 5737 views 0 times favorited 15 replies Add to Favorites Watch
View moke's profile
moke
1279 posts in 3015 days
04-27-2016 05:27 PM
I bought a Laguana Revo 18/36 wood lathe that I posted earlier. I need to make just a few metal pieces here and there, and I have thought of getting a metal lathe, but I’m afraid I would not use it very much at all. So I was wondering if there was some people here that have had experience with the x-y compound table available for grizzly…they have three, I was thinking this one
http://www.grizzly.com/products/5-1-2-x-12-Compound-Slide-Table/H7979
I have some questions….I assume that I have to buy a tool block to add to this…how do I get it to the correct height? Is this a good idea at all? Is it going to be hard on my lathe…which is 3 hp and built like a tank?
Thanks in advance to anyone that can help…..I have a ton of machinst tools. My dad was an engine/turret lathe operator for much of his life, so I have many precision tools and even some cutters. I also know some of his friends that can help me learn the basics.
Mike
-- Mike
15 replies so far
View MrUnix's profile
MrUnix
7107 posts in 2438 days
#1 posted 04-27-2016 05:44 PM
I don’t have any experience with that milling table, but you could probably get it to work for limited metal turning if you can figure out a way to secure it to the lathe bed and then find a tool holder for it. Most ‘lamp-post’ tool holders pivot to adjust for height adjustment (roughly an inch or so)... and others can be shimmed to a certain degree to adjust for height. It wasn’t really designed for that kind of use, but I’ve seen crazier setups from some pretty creative people. Your lathe runs on a VFD, so certainly can be made to go slow enough – and 3HP should be fine (my South Send only has a 1/3hp, although it’s running off a countershaft).
Or, you can do like I did and just scout out a deal for a real metal lathe on CL ;-)
I’ve seen those little mini lathes like HF sells pop up now and then for not much more than what you would pay for the milling table, tool holder and everything else you would need. Check out the littlemachineshop for some comparisons of fairly cheap miins… or keep an eye out for a nice used Unimat or Sherline... way cool mini-lathes that can also be configured for milling, boring, drilling and lots of other stuff.
View Wildwood's profile
Wildwood
2529 posts in 2373 days
#2 posted 04-27-2016 09:03 PM
Have the same question and every year look at tables & accessories from the Grizzly catalog. Like Brad said getting the right tool holder & cutters essential. Too many moving parts for me to deal with!
Have seen one example posted over at IAP several years ago cannot remember the wood lathe just know smaller than yours and mine.
In 1920’s & 1930’s could buy whole shooting match from most lathe manufacturers here.
Think would try to solve height difference using plywood as needed to start out before going to local welding/machine shop in my town for something more permanent.
Brad suggestion for finding and inexpensive new/used metal lathe might be right on.
-- Bill
View Nubsnstubs's profile
Nubsnstubs
1434 posts in 1969 days
#3 posted 04-28-2016 03:57 PM
Mike, I would think once you started making those here and there metal parts it would turn into, “now I need this”, and when “this” is done, “another this”. It would turn into a vicious cycle of never ending tool making… It’s gratifying making your own tools, but it takes some time away from wood turning. With good planning, the two can be managed to look like no time has been lost to wood turning.. Actually, you might gain more turning time as you’ve got to check out the tool you just made. If it doesn’t do the job, back to the drawing board until you get it right equals more wood turning time. ..........
I’m sorry I can’t give you sources of a how to, but I will encourage you to pursue your interest. A 3 jaw metal working chuck might be better than using the chucks designed for wood turning.. ........ Jerry (in Tucson)
View hairy's profile
hairy
2783 posts in 3771 days
#4 posted 04-28-2016 09:50 PM
I bought this at a yard sale last year and am playing around with it. I’m trying to use it for wood, not metal.
No success to boast about yet. I built a base so that the cutter is at center height. I purchased a 1/2” bar , 12” long, and square edged carbide cutters from Capt. Eddie.
HF sells cross slide vises. http://www.harborfreight.com/6-inch-cross-slide-vise-32997.html
This guy has a great setup for making banjos on a wood lathe. Maybe his method to attach cutters could be what you need. https://www.youtube.com/watch?v=_E3VG6dsVYs!https://s3.amazonaws.com/vs-lumberjocks.com/o6d5a33.jpg!
-- My reality check bounced...
View HapHazzard's profile
HapHazzard
116 posts in 1107 days
#5 posted 04-28-2016 11:30 PM
If you want to use it to hold tools, wouldn’t a cross-slide vise work better?
But I’m with Brad on this one. Wood lathes are prone to harmonic vibration, and once the cutter starts to chatter, it’ll just keep getting worse.
-- Unix programmers never die; they just > /dev/null
View moke's profile
moke
#6 posted 04-29-2016 05:25 PM
Thanks guys for the advice and suggestions….
Brad——-I have been eyeing the grizzly catalog for the 9×22 and the 10×24?.....not sure on the bed length….but then I would need a roller bottom and with the lathe I’m at 2k again or close. I watch CL everyday, and there is seldom ever anything I consider a great deal, and only occasionally even a fair deal. But I keep watching….
Hairy- That is a great set up..thanks for showing….I may just do that and adapt it to my needs a little more.
Jerry in Tucson- In a former life I drove a Funny car and a Pro Stock for a season or two…I was 21..you know all testosterone and no brains…..is it Thunderbird raceway in Tucson? I have a story about a lightning storm there…..it was hitting the ground!!!
Anyway I make too many excuses now to not work on my projects in favor of this or that for my shop!
Bill, Im on IAP too, not very active but could you PM me the thread?
Hap Hazzard—-thanks for the insight! I really don’t want to do much, just the occasional tool for me….couldnt I file it a little if I get vibration then try a lighter cut?
THanks again all
Mike
-- Mike
MrUnix
#7 posted 04-29-2016 06:48 PM
Yeah, CR probably isn’t the center for tool deals :)
But if you are willing to drive up to, or frequent the Chicago area, you can find lots of good stuff up around there. Here is an example – a really nice Unimat SL for $350 in fantastic condition, in it’s original box and includes some extras: http://chicago.craigslist.org/nwc/tls/5557667633.html
Might be on the upper end of what it’s worth, but they are very versatile machines. I’ve got one of those (an older DB200 model) and they can ba used for just about any material – metal, wood, plastic, etc…. With the (missing on that lathe) vertical column and headstock adapter, it turns into a drill press and milling machine, and has lots of other optional stuff for sanding, buffing and other machining type operations. The headstock/motor come off as a single unit, and they even had an adapter that turned it into a handheld drill at one point!!
PS: That is one of the few machines I have that wasn’t made in the US… it was made in Austria :)
Wildwood
#8 posted 04-29-2016 07:59 PM
Mike tried search feature without any luck, has been several years ago! So Googled your title and this is what came up with.
http://www.penturners.org/forum/f30/can-you-convert-wood-lathe-metal-lathe-yes-sort-94996/
http://lumberjocks.com/Bluepine38/blog/20727
Think Hairy is onto something good too!
-- Bill
hairy
#9 posted 04-29-2016 10:45 PM
A few years ago I bought this set of plans from ebay.
http://www.ebay.com/itm/HOW-TO-MAKE-A-COMPOUND-SLIDE-REST-FOR-A-WOOD-LATHE-/222080761810?hash=item33b50b7fd2:g:iFcAAOSwz2lXCVdD
The plans gave me a headache so they got put away. I’m not a plan kinda guy, but maybe you are. They actually are good plans. Maybe someday…
View Woodknack's profile
Woodknack
12465 posts in 2619 days
#10 posted 04-29-2016 11:16 PM
That plan is from Popular Mechanics, 50’s I think. They published a simpler version decades prior.
View moke's profile
moke
#11 posted 04-30-2016 04:44 PM
you guys don’t think doing this would damage the lathe would you?
-- Mike
hairy
#12 posted 04-30-2016 05:34 PM
I use this arrangement to attach all the jigs I make to my lathe. T nuts in the bottom piece. It cannot hurt the lathe. I use good quality baltic birch plywood. It can easily slide in the ways and stays put.
Woodknack
#13 posted 04-30-2016 07:24 PM
View Bluepine38's profile
Bluepine38
3380 posts in 3324 days
#14 posted 05-02-2016 04:53 AM
lumberjocks.com/reviews/product/1808
This is a review of the Delta accessory made for my 1950’s era Delta lathe. I use it for wood turning and
have turned a few electric motor armatures and have done light machine work with it without any problem.
I am sure you could adapt the Grizzly Compound slide table and tool holder to do the same thing, as
nubsnstubs stated it could add up in time and money. Since my shop exists to keep me off street corners
and out of trouble, I do not worry about the time angle.
-- As ever, Gus-the 80 yr young apprentice carpenter
HapHazzard
#15 posted 05-04-2016 09:46 AM
Hap Hazzard—-thanks for the insight! I really don t want to do much, just the occasional tool for me….couldnt I file it a little if I get vibration then try a lighter cut?
Yes, a file would be the way to fix it. Also, if you can cut from one end and keep the pressure axial it seems to go more smoothly.
you guys don t think doing this would damage the lathe would you?
- moke
Not if you take it slow and don’t try to remove too much metal at once. The worst you can do is wear out the bearings, and they can be replaced.
