slide out shelves
Forum topic by StiltzWi posted 04-27-2016 12:52 AM 580 views 0 times favorited 3 replies Add to Favorites Watch
View StiltzWi's profile
StiltzWi
34 posts in 780 days
04-27-2016 12:52 AM
I will be building some slide out shelves for our kitchen pantry. I estimate the shelves to be little over 14 inches wide and 22 inches deep with 1/2 maple sides dovetailed together about 3-4 inches tall. My question is if I use 1/4 inch maple plywood for bottoms is that going to be strong enough? the glides will support 100lbs. I would hate to build them only to have the bottoms fall out. I am planning on doing dados for the plywood bottoms.
3 replies so far
View jbay's profile
jbay
2289 posts in 899 days
#1 posted 04-27-2016 01:01 AM
They’ll be fine.
View JBrow's profile
JBrow
1354 posts in 920 days
#2 posted 04-27-2016 02:23 AM
StiltzW,
At 14” wide, I agree with jbay. ¼” plywood will probably be ok. However, your question suggests a worry which is easily addressed by using ½” plywood which can be rabbeted to fit a ¼” dado in the sides. If the glides require a ½” bottom clearance, this means you lose a ¼” of spacing between the shelves, but you gain peace of mind.
View rwe2156's profile
rwe2156
2926 posts in 1481 days
#3 posted 04-27-2016 12:07 PM
Personally, I would never use 1/4” thick bottoms in a kitchen slide out if for nothing else every time you put a cast iron pot on it you will be reminded that you went cheap with the drawer.
I doubt it would ever break, but why not just go 1/2 and be sure?
Start the dado 1/4” from the bottom and make it a full 1/2”. Don’t worry about losing space it won’t matter in the end.
When I built my kitchen I predrilled shelf pin holes in the sides and mounted the runners to a 3/4” strip (needed to anyway to clear doors. If you have a face frame you will need them anyway). Placing the runners top of the pins you can have adjustable slide out shelves. This worked great especially when my wife decided to store the crockpot down there.
Oh yeah, and you need to put a screw in the back to keep it from tipping when pulled out ;-)
Good luck with your project.
