Milling Logs on the Laguna 14 Twelve Bandsaw - Resaw King
Forum topic by Woodworker101 posted 04-25-2016 10:57 AM 733 views 0 times favorited 1 reply Add to Favorites Watch
View Woodworker101's profile
Woodworker101
22 posts in 1897 days
04-25-2016 10:57 AM
Topic tags/keywords: milling bandsaw oak walnut ash maple
G’day LJ’s
I have a question for you all. I’ve gotten to the point where I want to start milling small logs which will be around 200mm – 300mm in diameter (8” – 11” inches). When I bought my Laguna 14/12 I also bought the Resaw King blade to suit it. The blade alone cost me $250 AU.
Is it okay to use this particular blade for milling wet logs?
The reason why I ask is because I was thinking about using the Resaw King to mill the logs today however I wasn’t sure what would happen to the blade afterwards, whether the blade would rust due to the wetness of the timber or damage it in some way so I didn’t want to risk a $250 blade.
Also the species that I am looking to mill will be Canadian Maple, Oak, Walnut, Ash and Australia natives (which are tough as nails).
Many thanks.
Jackson
-- Jackson, Australia,http://www.jacksonsfinecarpentry.com.au/
1 reply so far
View Aj2's profile
Aj2
1436 posts in 1823 days
#1 posted 04-25-2016 01:56 PM
No don’t used the RK for wet woods it will dull it very quickly.Theres not enough set in the blade.Only dry wood for the RK.I found out the hard way I used a RK to cut Douglas fir that had a high moisture content.It didn’t last very long and needed to be sharpened.
-- Aj
