Finishing question for work benches exposed to elements
Forum topic by Gambrell posted 04-25-2016 01:05 AM 567 views 0 times favorited 5 replies Add to Favorites Watch
View Gambrell's profile
Gambrell
19 posts in 809 days
04-25-2016 01:05 AM
I have a covered back porch that is open to the elements. I am planning to build a work bench, and other work surfaces for hand tool woodworking and keep them on this porch. When it rains they should stay dry unless the wind is bad in which case they may get slightly damp from misting.
I know benches are not normally finished with varnish and such, but does anyone have a recommendation or tips on what I could do to make these work benches weather resistant (indirect sun, direct humidity, and infrequent misting from hard rains). Again, they will be covered by a ceiling but not housed in a traditional shop. If it helps I live in Alabama so heat and humidity is the norm 9 months per year.
Is this a bad idea? Or is this very doable?
5 replies so far
Gambrell
#1 posted 04-25-2016 01:07 AM
On a side note I will be storing my tools in a storage closet inside an English Tool Chest that I plan to build from Schwarz’s anarchist tool chest design so they will not be exposed to the elements.
View MNgary's profile
MNgary
298 posts in 2411 days
#2 posted 04-26-2016 09:09 PM
A semi-transparent stain (the type used on exterior siding) would be my choice.
-- I dream of a world where a duck can cross the road and no one asks why.
View JayT's profile
JayT
5621 posts in 2205 days
#3 posted 04-26-2016 09:14 PM
Use a wood that is weather resistant and don’t rely on the finish. You’ll be wearing the finish off as you work, in addition to nicks, cuts and other assorted oops moments. so would have to constantly be reapplying finish to protect the surface.
Using something like white oak, black locust or other weather resistant wood will be a better solution, IMHO. Even cypress, while much lighter and softer, could make a good bench that would stand up to some weather.
Gambrell
#4 posted 04-27-2016 02:07 AM
Thanks guys
View Jim Finn's profile
Jim Finn
2656 posts in 2916 days
#5 posted 04-27-2016 12:14 PM
A tarp to cover it all would help.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
