Double Sided Tape for Templates
Forum topic by Charlie_Wintercoats posted 03-25-2010 07:38 PM 16338 views 0 times favorited 15 replies Add to Favorites Watch
View Charlie_Wintercoats's profile
Charlie_Wintercoats
36 posts in 3478 days
03-25-2010 07:38 PM
I am making some small wood pieces (less than 6” x 6”) and will be using a home made router table with a straight bit with bearing. I have to attach the template temporarily without making holes or gluing. I have many pieces to make so speed is a concern. I have heard of using double sided tape for this but cant find a good kind what are your recommendations? I don’t want anything sticky on the wood when I remove it. Reusable would be awesome.
Thanks
15 replies so far
27250 posts in 3847 days
#1 posted 03-25-2010 11:52 PM
Charlie, when I need to do something like this I use carpet tape. It is readily available. You may be able to reuse it a time or two but I just cut a new piece when I want to attach a template.
View Pete_Jud's profile
Pete_Jud
424 posts in 3778 days
#2 posted 03-26-2010 12:04 AM
Golf grip tape works great for me, about 5 bucks a roll.
-- Life is to short to own an ugly boat.
13606 posts in 3366 days
#3 posted 03-26-2010 12:17 AM
can you drill a hole in the jig ,
and put your shop-vac hose in it ,
and some handles .
cut your parts slightly over size ,
and ’ suck ’ them to the pattern ,
and route with a flush trim bit .
try it on scrap first .
View Glen Peterson's profile
Glen Peterson
556 posts in 3081 days
#4 posted 03-26-2010 02:08 AM
I’ve always used carpet tape. I have rolls of golf tape from the last time I regripped my clubs. I’ll give it a try. I trust Patron’s experience, but I’ve never tried the suction method he suggests. I’ll try that too.
-- Glen
#5 posted 03-26-2010 02:41 AM
i just tried this ,
and have to say that you need a powerful suction .
my dust collector wasn’t strong enough ,
and my little toy shopvac wasn’t either .
maybe one of those 2 1/2 ” shopvacs might work .
View closetguy's profile
closetguy
744 posts in 3917 days
#6 posted 03-26-2010 04:19 AM
I always use carpet tape. It only takes a little. Too much, and you will be prying it loose with a crowbar.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
View jm82435's profile
jm82435
1285 posts in 3767 days
#7 posted 03-26-2010 05:41 PM
I think Patron has a good idea, you might ask kunk, he obviously uses vacuum holding for something like you describe:
http://lumberjocks.com/projects/29281
-- A thing of beauty is a joy forever...
View David Craig's profile
David Craig
2137 posts in 3134 days
#8 posted 03-26-2010 10:28 PM
Interestingly enough, my favorite double sided tape I found at Walmart. This was after having no luck at some of the home improvement stores. The brand is “Duck Tape” and their double sided tape is very strong. When you are done with the cutting, if you find that gentle force is not enough to pull them apart, tap the top piece with a rubber mallet. The shearing force will pull them apart without damaging the wood.
David
View Ger21's profile
Ger21
1074 posts in 3156 days
#9 posted 03-27-2010 06:33 PM
I’ll second the golf grip tape. I used to use carpet tape, but now always use golf srip tape. If you have a local Golfsmith store, you can get it there.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View Eli's profile
Eli
141 posts in 3031 days
#10 posted 03-28-2010 05:33 AM
3M makes a great double sided tape that doesn’t leave a residue. I haven’t been able to find it in any stores. I’m told you have to order it directly, and in large quantities.
Eli
Charlie_Wintercoats
#11 posted 03-29-2010 08:10 PM
Carpet tape worked like a charm. Thanks.
View motthunter's profile
motthunter
2141 posts in 3824 days
#12 posted 03-14-2013 12:35 AM
carpet tape eats grain and leaves residue you wont notice until you go to finish and start to cry from the haze. Use Avery Dennison tape. I swear by it. It is designed to leave no residue and holds great.
-- making sawdust....
View Quanter50's profile
Quanter50
278 posts in 2321 days
#13 posted 03-14-2013 01:12 AM
Check “ULINE”. I just bought two rolls of 1/2” double stick tape for use with my new sign templates. 1/2” x 36 yds for $4.70. Ordered it online and had it the very next day!
View Scott C.'s profile
Scott C.
158 posts in 2076 days
#14 posted 03-14-2013 02:04 AM
I don’t have a specific recommendation, but the thicker spongy stuff can allow the template to shift around a bit when applying pressure. It’s slight, but can trouble sometimes.
-- measure twice, cut once, swear and start over.
View NiteWalker's profile
NiteWalker
2737 posts in 2602 days
#15 posted 03-14-2013 02:45 AM
This is the best I've ever used.
A little goes a LOOOOONG way!
