Table Saw How To?
Forum topic by Michael James posted 03-25-2010 07:06 PM 1750 views 0 times favorited 21 replies Add to Favorites Watch
View Michael James's profile
Michael James
89 posts in 3015 days
03-25-2010 07:06 PM
Topic tags/keywords: question tablesaw
Hi there,
I have real trouble ripping plywood on my table saw. i can’t really justify a track saw and don’t have room to build a panel saw.
The trouble I have is binding and getting a good cut. Can anyone point me in the direction of some technique artiicles or videos that might help me get better at it? It really sucks when you ruin a $60 sheet of plywood.
I’m also open to any pointers people can give me.
-- Michael James - www.michaeljames.ca
21 replies so far
View HokieMojo's profile
HokieMojo
2104 posts in 3695 days
#1 posted 03-25-2010 07:22 PM
do you have infeed/outfeed tables. I don’t, but from what I can tell, it makes a world of difference. Instead, I just use a circular saw.
View JimmyNate's profile
JimmyNate
124 posts in 3317 days
#2 posted 03-25-2010 07:33 PM
Infeed/outfeed support is important. Long rails for the fence help you fit it on. Use a splitter to help with the binding. Check the squareness of the fence to ensure it isn’t tapering toward the blade near the back. Be sure to feed it through with support in 3 directions: against the blade, down agains the table and right against the fence. You shouldn’t have true binding with plywood so my guess is that either the fence is out of square or you arent’ keeping the piece seated squarely agains the fence. Also, plywood often does not have perfect edges. Consider cleaning up an edge before making your cuts. You can also pre cut to dimensions close to your final size using a circular saw and then clean up the edges on the table saw once the piece is a more managable size if that’s a problem.
-- "We are what we repeatedly do; excellence then is not an act but a habit." ---Aristotle
View PurpLev's profile
PurpLev
8534 posts in 3615 days
#3 posted 03-25-2010 07:33 PM
I also use a circular saw for cutting sheet goods. using a good (can be shop made) straight line cutting jig can also eliminate any need to ‘finish up’ the cuts on a table saw, and have ready to use panels.
JimmyNate
#4 posted 03-25-2010 07:35 PM
The type of blade could play a role but I haven’t tried enough different blades to help you there.
View JJohnston's profile
JJohnston
1622 posts in 3258 days
#5 posted 03-25-2010 07:35 PM
In my experience, it’s very difficult to get a good cut on a big piece – it’s just too hard to handle. However, you don’t need a tracksaw to break a sheet down into manageable size. Just rip off a piece 8 to 12” wide from the factory edge, and use that as a straightedge to guide a circular saw. You measure the distance from the edge of the shoe on your saw to the blade, and offset the straightedge the same distance from the cut line. Use a couple of small C clamps to hold the straightedge to the sheet being cut. If you want more convenience, glue another straightedge to the top of the first one a little farther than the offset distance you already measured, and cut it – then you have an edge that represents exactly where the cut will be, so you won’t have to do any measuring.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Michael Murphy's profile
Michael Murphy
453 posts in 2972 days
#6 posted 03-25-2010 07:40 PM
You don’t mention the quality or size of the saw you are using so it’s hard to evaluate what might be happening. The bigger the panel the harder it is to control. You could use a circular saw to rip it into suitable rough size pices first, like rip in half then trim to final width on the T saw.
Binding could be the result of an out of adjustment fence or other saw alignment issues like the blade not being parallel to the miter slots and fence. Make sure the saw is adjusted properly according to the instructions in the owners manual. The fence should be a few thousands of an inch farther away from the blade a the far end than the near end. It needs to be tightened in such a way to prevent movement of course, and needs to be long enough to be able to keep the edge of the panel against it easily.
Adequate support for the infeed and outfeed is necessary for bigger panels. If you are using in or outfeed rollers to support the panels make sure they are lined up properly so they dont pull the panel away from the fence as they roll, and adjust them to the right height. Make sure the table and fence are clean. I generally use paste wax on mine to make things slide better, on the table, insert, and face of the fence.
Bad cut quality could be just the choice of blade. Just look at some of the other threads about blade choices for table saws. I generally keep a 60 t carbide tipped ATB blade on my Unisaw, works well for everyday stuff. I have a drawer full of other blades from back when I was building cabinets full time that do specialty things like cut melamine without chipping or geared for plam cutting. Whatever blade you use should of course be Sharp and make sure it isn’t bent or out of balance.
-- Michael Murphy, Woodland, CA.
View Moron's profile
Moron
5032 posts in 3860 days
#7 posted 03-25-2010 07:41 PM
many answers aside from alignment of fence and blade
reduce the friction of bed, fence and material by soaping or dry lubricant.
fixed or portable outfeed tables or at least another set of hands are a “must” otherwise its kinda impossible.
Rip over sized with a circular saw and straight edge into managable sizes, then rip to the right size on the TS.
acquire some cheap crap plywood, the kind most folks throw out. practice ripping again and agian and again cuz as they say,.............practice makes perfect.
What kinda hardware did you use on the Murphy bed?
Michael James
#8 posted 03-25-2010 07:47 PM
Wow..this is great! Thanks so much for all the feedback. It sounds like I need an outfeed table but I really like the idea of rough cutting first with a circular saw.
What’s the best blade for a circluar saw for hardwood? 40T? I have a framing blade, but that just makes a mess…
PurpLev
#9 posted 03-25-2010 07:51 PM
I’m using a Frued Avanti 40tooth blade in my circular saw and the cuts are unbelievably clean -seriously.
Michael James
#10 posted 03-25-2010 07:54 PM
Thanks…I’ll pick one up.
For those of you who asked, I have the Rigid combination saw with a cast iron top. It’s a great saw for me and for the limited space I have – I think I’ll check the adjustments and use a circular saw to begin the process. I’ll build an outfeed table too that will assist in this.
Thanks to everyone for your help.
JimmyNate
#11 posted 03-25-2010 09:23 PM
If you cut alot of long stock, consider building a long outfeed table. I added a 2 ft outfeed table to my saw but I find I still want some kind of support for large/long stock like height adjustable rollers on both the infeed and outfeed ends of things. I haven’t coughed up the money for rollers yet so I just use a sawhorse adjusted to about half an inch to an inch below the outfeed table height and placed a couple feet back from the outfeed table. It’s a decent solution, but skipping the rollers and just having a 4 or 5 foot outfeed table would be nice.
HokieMojo
#12 posted 03-25-2010 09:30 PM
here is what i use:
Click for details
View Todd Clare's profile
Todd Clare
67 posts in 2952 days
#13 posted 03-25-2010 09:58 PM
I have a Delta left tilt contractor saw and had a heck of a time getting the blade/trunnion aligned properly. Somehow “hit it with a hunk of wood” and “align it to 1000th of an inch” didn’t go together very well for me.
I opted to get a PALS Contractor Saw Alignment System and I can tell you it made a world of difference. Combine that with the cheapest Harbor Freight dial indicator screwed to a scrap of wood and my miter gauge, and I got the saw/slots/fence/miter/etc. aligned wonderfully and am making fantastic cuts ever since.
My next project is an outfeed table for all the reasons listed above.
-- Todd (Denver, CO -- Highlands)
View David Kirtley's profile
David Kirtley
1286 posts in 2965 days
#14 posted 03-26-2010 03:54 AM
I can’t imagine even messing with a table saw for sheet goods. The clamp on saw guides and a circular saw are much nicer to work with, give better cuts and a lot safer.
I do lust after some of the new plunge cutting saws with the aluminum track.
View Ger21's profile
Ger21
1074 posts in 3098 days
#15 posted 03-26-2010 04:46 AM
I have a panel saw for crosscutting, but rip all my 4×8 sheets on my Unisaw. As mentioned, you need a good fence, and an outfeed table. I hold the outside corner of the sheet, diagonal from the fence. That way you can push forward and against the fence at the same time. I slide the sheet up near the blade, and against the fence, and rock it a little to make sure it’s against the fence, and then start pushing. As long as the sheet is against the fence (all along the fence, so it’s parallel), once you start cutting, you shouldn’t have a problem. If you’re getting binding, there’s a good chance you’re starting the cut with the sheet not parallel to the fence.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
