Drills bit selection and variety
Forum topic by Nick posted 04-22-2016 10:10 PM 1072 views 0 times favorited 22 replies Add to Favorites Watch
View Nick's profile
Nick
5 posts in 764 days
04-22-2016 10:10 PM
Topic tags/keywords: tip question drill-driver
Being new to woodworking, I am looking for advice on purchasing quality drill bits and the types/variety I should invest in. One of my friends is pushing me to buy a Ryobi drill bit set with something like 300 pieces to it. It has a full set of paddle bits, hole saws, metal/wood/masonry bits, nut driver bits… I’m just not sure of the quality of the product.
Is it better to get a big package like this, or is it better in invest in smaller sets? Any tips on what to look for and where I should invest?
Thanks!
Nick
22 replies so far
View Lee's profile
113 posts in 873 days
#1 posted 04-22-2016 11:17 PM
Well, not sure about the quality of Ryobi bits, but for woodworking a set of forstner, brad point, and spade bits are more useful than regular twist drills. I’m not saying you shouldn’t have a set of twist drills, because I do use them. hope this helps.
-- Colombia Custom woodworking
View conifur's profile
conifur
955 posts in 1146 days
#2 posted 04-22-2016 11:53 PM
First ditto Lee,
but that kit depending on price and needs is a good starter kit, not just for wood working but to have around the house for other task.
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#3 posted 04-23-2016 12:03 AM
http://www.leevalley.com/en/Wood/page.aspx?cat=1,180&p=42240
http://www.leevalley.com/en/Wood/page.aspx?p=53317&cat=1,180,42240
Kudos on doing your homework first and purchasing quality vs quantity.
And a belated welcome to Lumber Jocks!
View jonah's profile
jonah
1696 posts in 3293 days
#4 posted 04-23-2016 01:23 AM
I have a set of Ryobi drill bits. They are pretty much garbage, on the level you’d get at Harbor Freight. They’re decent at first, but they dull, break, or just quit far, far too easily.
I’d probably get a set of cheapo twist bits for general use, but I would definitely spring for a decent set of brad-point bits as well. They’re much more useful in woodworking. I’d buy forstner bits as you need them, or spring for a set if you need more than one or two right away.
View jumbojack's profile
jumbojack
1676 posts in 2619 days
#5 posted 04-23-2016 01:31 AM
I bought an indexed set from ?? I don’t remember….....but they go from 1/2”-1/16” by 64ths. Invaluable. I use them constantly. It came with a plastic card with all the hole sizes. You can check the exact bit you need by first indexing the part. They are brad points. Bout once every two years I get a set of twist bits, what ever happen to be on sale usually. I got a set of Foerster bits from Woodcraft and they are ok. I just noticed the 3/4” bit is burned on one edge so Ill have to replace it.
View BurlyBob's profile
BurlyBob
5491 posts in 2260 days
#6 posted 04-23-2016 02:17 AM
I’ve got agree with Lee. They all have their place and are invaluable when you need them.
View bigJohninvegas's profile
bigJohninvegas
448 posts in 1456 days
#7 posted 04-23-2016 03:34 AM
A nice set of brad point bits, and a set of forstner bits should get you started.
I have the brad point set from MLCS. They seem to be good, have had them for a couple years.
I bought the harbor freight forstner bit set about 3 years ago on a budget. Expected to wear them out in a hurry,
But was new woodworker and figured they would get me started. I actually still use the set, though the couple bits I use most could use to be sharpened.
I would not get in a hurry to buy more till you see what you need. I have a hand full of tools that I bought as a new woodworker, thinking that I needed it, only to never use.
I think the best advice I can pass on that all the veteran woodworkers gave me was save your money and buy it when you need it.
Good luck.
-- John
View Woodknack's profile
Woodknack
11608 posts in 2375 days
#8 posted 04-23-2016 04:11 AM
I can’t answer your question directly but in my experience, the most important in order are twist bits (for general purpose), spade bits, brad points, then Forstner bits. Some people hate on spade bits but I’ve always had good results but they don’t produce flat bottom (sorta) holes like Forstner.
View davezedlee's profile
davezedlee
28 posts in 819 days
#9 posted 04-23-2016 12:38 PM
the other biggest thing you’ll find with cheap bits is the amount of wobble (or runout)
sometimes its acceptable for wood projects, but if trying to drill harder metals at all, the bit just scrapes around in a circle slightly larger than the bit’s diameter, and never really cuts unless using overly extreme amounts of downforce from a drill press; almost impossible with a hand drill
the quality control and extreme precision are what drives up the price, but try drilling the center of a hub or wheel with a crappy bit and you’ll find out the hard way…
View Nick's profile
Nick
5 posts in 764 days
#10 posted 04-23-2016 03:03 PM
This is great – thank you!
What about countersink bits? I’ve seen you can buy the countersink bits set OR you can buy a standalone countersink. Any tips on what to look for with those?
Woodknack
#11 posted 04-23-2016 05:02 PM
I have both but use the Dewalt countersinks with tapered bits the most.
View MrUnix's profile
MrUnix
6703 posts in 2193 days
#12 posted 04-23-2016 05:56 PM
Buy ‘em as you need ‘em. Twist bits are usually first as they are general all around bits that can be used everywhere. Next project you need to drill some stuff, if you don’t have the bits you need already, get ‘em. Over time, you will have a selection of bits you actually use, not just a set of bits that you may only use 10% of.
View oldnovice's profile
oldnovice
6841 posts in 3362 days
#13 posted 04-23-2016 06:07 PM
I do not like Ryobi products because they are rather poor quality.
I bought a set of Ryobi counter sinks and they are terrible.
My Ryobi detail sander is laying in a drawer, unused for nearly 10 years, because it vibrates way too much to hold it for any amount of time.
The problem with buying a complete set is that you probably will never use every bit in a set much like a complete set of router bits. You will replace ones you use more often and, again, there will be some never, or very rarely, used.
I have a fractional and number drill index that I populated with the bits need.
I do have a complete set of Forster bits I bought at Costco.
If you are only into woodworking a set of brad point bits is a good choice.
That my two bits worth!
View MrRon's profile
MrRon
4764 posts in 3238 days
#14 posted 04-23-2016 06:21 PM
For woodworking, a set of brad point bits and a set of forstner bits are essential. With brad point drill bits, it is not necessary to have twist drills. Twist drill bits are fine for general use and metal, but get a good set of HSS twist drill bits. Cheap twist drills are not always straight, so when a hole has to be “right on”, you can only get that with a perfectly straight bit. Twist drills and spade bits will leave jagged edge holes which is ok as long as the hole will not be visible; a pilot hole for a screw for example. Ryobi is not quality bits, but better than nothing for general use. I wouldn’t depend on them for use on fine woodworking or cabinet making.
bigJohninvegas
#15 posted 04-23-2016 07:38 PM
I have a fuller set of tapered counter sink bits.
Dewalt makes the same bit a little more affordable.
Not really anything you need right away.
I had the need to fill the screw holes on a few projects.
Got a set with a plug cutter. Nice to hide screw holes.
-- John
