Festool MFT or EZ Smart or Dewalt Table Saw
Forum topic by pcox posted 04-22-2016 07:52 PM 1637 views 0 times favorited 7 replies Add to Favorites Watch
View pcox's profile
26 posts in 695 days
04-22-2016 07:52 PM
I am new to woodworking and would like to purchase some power tools that are compact and can be used in my garage and then put up as needed if I want to pull my car into the garage. I have looked at some small table saws and believe the best option for me would be the Dewalt DWE7491RS if I go the Table Saw route. However I have also recently discovered the track saw systems like the Festool and EZ Smart. These seem like safer options and I find myself interested in going this direction. Although this will be a bit more expensive.
I plan to use the tools for building things like a new bench for our front porch and a linen cabinet for our master bathroom. Maybe a bookcase as well.
Here are the options I am considering…
TS55 Saw – $660
MFT3 Table – $504
Total – $1164
EZ Smart
Makita 5008 Saw – $319 (setup to work with the EZ System.)
EZ Smart Table – $999
Total – $1318
Dewalt DWE7491RS Table Saw with Stand – $579
I would appreciate your comments on these options for a new woodworker.
7 replies so far
View waho6o9's profile
8127 posts in 2507 days
#1 posted 04-22-2016 08:28 PM
Save your lungs and get a track saw with dust extraction :)
+1 for the Festool system
View pcox's profile
#2 posted 04-22-2016 08:32 PM
- waho6o9
That’s a good point because I do have allergies and mild asthma at times. Thanks for your reply!
View Neilswoodcraft's profile
9 posts in 698 days
#3 posted 04-22-2016 11:37 PM
Festool track saw for sure. I have a ts75 track saw an love it. It’s a little bulky for some stuff but The 55 is to small for some stuff. I also love a few other Festool tools I have. There expensive but in my oppoion there worth the cost if your serious about woodworking. Easy, accurate, versitle, quality is what you get with Festool.
View Sloopmk's profile
39 posts in 724 days
#4 posted 04-23-2016 12:07 AM
I’d go tablesaw. Festool is amazing, I drool over them constantly, but for a beginner you may not need such a precise and professional tool. Wear a dusk mask while you use it and you’re fine. Use all the leftover cash to buy other hand tools you’ll need (sanders, clamps, router, etc).
View JayCee123's profile
200 posts in 695 days
#5 posted 04-23-2016 01:44 AM
Hi Pat
What sold me on the Festool system was primarily the dust collection capability. When your evaluating your options you need to consider the additional cost of a dust extractor for the TS55, unless you already have a dust collector. In my case, I purchased the CT26 ($675), I don’t recommend anything smaller. I also purchased the larger 50mm diameter hose ($125) which further improved dust removal when using the TS55. No doubt the Multi Function Table and Dust Extraction are a bit expensive, however they do form the heart of the Festool system, which makes the cost a little more tolerable. Should you go with the Festool setup you’ll find the table knock-down and set up a breeze. The track saw cuts are very accurate, repeatable and glass smooth, and thats with the TS55 stock blade. The table is so much more than just a cutting surface. The perforated top with some of their accessory clamps make difficult clamping and hold-down a breeze.
View pcox's profile
#6 posted 04-24-2016 05:37 PM
Ok, I have decided for safety and dust reasons that I am going to start out with a TS55 and a dust extractor (I have not decided yet between the Midi and the 26.) Along with that I have a 10” miter saw that will cut up to 2×6. So any crosscuts larger than this will need to be done with the TS55. Would I benefit from the MFT3 table or could I easily make my own table with rails and save some money? I like the idea of the rails on the MFT3 table. It looks like it makes it easy to make square cuts.
View jgt1942's profile
201 posts in 1819 days
#7 posted 04-24-2016 11:21 PM
I have a DeWalt table saw but if I were buying a new saw I’d get the SawStop.
I was lucky and found a SUPER deal on the Festool TS55 and LOVE it! My shop is in my garage where the central vacuum for the house is located. I ran a new line from the CV to my work area with a drop from the ceiling and connect the TS55 to it and it captures a huge percentage of the dust when cutting. I’m really surprised as to how much I use it and for full sheets of plywood it is a must. I cannot do all of my cuts with it but I use it a lot more than I original though I would.
I suggest getting an extra track. I purchased the DeWalt clamps for the track mainly because they were about 1/2 the cost of the Festool clamps.
I have a bunch of 2×4’s 24” long that I use to support whatever I’m cutting
-- JohnT
