Hi there, Lumberjocks. I just found this forum and it’s awesome, but no time to waste. I have an old Taiwanese clone 14” bandsaw (labeled as a VBS-14, almost identical to the Grizzly G1019) that I recently inherited. It has seen little if any use the last 10 years, so I knew I would need to give it some care. Surprisingly, it ran quite well, good tracking and all. After a few minutes, the blade stopped turning and it made a horrible sound. Opening it up revealed the old (read original) rubber tire popped off the wheel. I looked it over and it was worn and cracked, so I bought a pair of urethane tires and put them on last night. I put my 1/4” blade on there tonight to see how it ran. I tensioned it up and started it for a cut, but I heard a kind of grinding noise. Turns out the urethane tires are thinner than the old rubber ones, so I had to raise the top wheel higher than before. This meant that the inner hub of the wheel on back side was rubbing against the housing by just enough to make plenty of noise and make me not want to continue on with it until I asked here.
So my question is: since the urethane tires are thinner than my old rubber ones, what should I do to alleviate the grinding? The options I have thought of so far are 1) grind down the edge of the wheel hub slightly to avoid the rubbing (the cheap option) and 2) buy a custom length blade that is slightly shorter than the 93 1/2” blade that is on there, like 93” or something (the more expensive option). Thoughts, ideas, advice? Thanks.
HF has 93” blades on their saws and sells them. Ya oughtta try gettin on eon a Ridgid that takes 93.5”. I ground under neath part thatthe wheel was rubbing. Well, actually hadda grind it just to get the blade on…and yes, I have new urethane tires on it too, didn’t help.
So I just had an idea. What if I used a longer, stiffer spring. This way, the blade would see more tension with less vertical displacement and could make it so that I don’t actually get the wheel up high enough to rub against the housing (it is rubbing on the little indentation on the back that therefore protrudes into where the wheel is). That would make it so that I wouldn’t have to use shorter blades. Besides, the spring in this thing is the original spring, and therefore most likely very tired (I’ve been eyeing the Cobra Coil, I must confess). It measures something like .75”x2.7” or thereabouts. Would this work or am I just fooling myself?
It may work , but keep in mind that your bearings could be tired also. So putting more pressure on them may make another problem. Not sure of this and I would probably try the spring, just thought I would mention it.
Are the new tires quite a bit thinner than the old rubber ones?
If the originals were 1/4” thick and the urethane ones are 1/8” thick, assuming the original wheels with tires were 14” dia., now with the 1/8” thick tires they are 13 3/4 diameter, that’s a difference of around .8 inches or 11/16” in circumference you have to make up for by raising the top wheel farther. Could that be causing the wheel to scrape?
The new tires are thinner. Also, I was thinking some more and I don’t think a new spring is a valid solution. The blade is a certain length and has to be displaced a certain amount to achieve a certain level of tension. A new spring will just make it so that I can get more tension (i.e., the appropriate amount of displacement) on bigger blades. It looks like I will either need to try to grind the casing a little bit so that the wheel doesn’t rub on it or get custom length blades made. Too bad I can’t find anyone locally who welds blades. Anyone know of anyone who welds blades in Syracuse, NY?
I would think a different spring would throw off the tension indicator if you have one. The spring compresses to get the desired tension on the blade. Different spring size would certainly affect that.
There is no saw sharpening shop in Syracuse? Tool Suppliers that make custom blades? Most of the ones I know of in my area can weld b s blades. Maybe you would have to mail it to someone to cut and re-weld it or go to the local Harbor freight and get one that’s just a bit shorter.
8794
224
28
61
81
1534
3552
15797
2038
495
2842
809
902
766
2740
1547
6162
