Table Finish
Forum topic by ScottM posted 04-21-2016 06:56 PM 575 views 0 times favorited 5 replies Add to Favorites Watch
View ScottM's profile
ScottM
647 posts in 2147 days
04-21-2016 06:56 PM
Looking at determining what finish to use for some small occasional tables. I was thinking about SW Kem Aqua but having a tough time finding it so now I’m thinking about Target EM6000. This is a lacquer so I’m wondering if I will have any issues with water marks. These will have dishes and glasses placed on them so should I be concerned about that?
I’ve never used the EM6000 before so just looking to see if I should be considering something else.
5 replies so far
ScottM
#1 posted 04-22-2016 11:54 AM
Anyone with info on EM6000 as a durable table top finish?
View AandCstyle's profile
AandCstyle
3052 posts in 2258 days
#2 posted 04-22-2016 12:44 PM
Scott, I love EM6000. I used it on this table with Target’s CL100. The table still looks like the day I finished it. It gets daily use with a klutzy SIL and 2 young girls. Good luck with your project.
-- Art
ScottM
#3 posted 04-22-2016 12:50 PM
Thanks Art. The tables are QSWO, my first using it, and hopefully I get the finish right like your projects. I’ve read good things about the EM line but haven’t pulled the trigger yet.
My biggest concern is water really. Do I need to worry about someone leaving a sweaty glass on it and having a water ring left behind?
View DrDirt's profile
DrDirt
4424 posts in 3743 days
#4 posted 04-22-2016 01:14 PM
lacquer is a great finish. I am still only using Solvent lacquer, not Waterbased.
But you should not have any watermark issues.
\Water rings are mostly found in ‘old’ shellac finishes that are breaking down.
AandCstyle
#5 posted 04-23-2016 10:56 PM
Scott, I don’t think water would create an issue if you use the CL100. I did a test once by leaving a bit of gin on a sample board overnight and it barely, but definitely did leave a mark. Alcohol softens the finish. Water would not bother cured EM6000. However, for a definitive answer, call Jeff Weiss at Target. He is a great guy and won’t steer you wrong. HTH
-- Art
