| Forum topic by HokieMojo | posted 1183 days ago | 1796 views | 0 times favorited | 15 replies | ![]() |
1183 days ago |
The reason that I ask is I think I have a plan to solve a lot of my storage problems. I’m planning to build a freestanding unit that will be 8 ft tall. It will be 3 feet wide and seperated into 3 sections. -The center section will be hollow and about 10” wide. This will hold full size sheet goods. -The left section (10” wide) will have 3 shelves at the top accessible from the left side. The bottom of the left side will have 5 shelves (more 4 ft long horizontal tubes running front to back) that will be accessible from the front to store long items like Dust collection pipe/hose, mid-length pipe clamps, and lumber cutoffs. -The right section will be 2 sets of shelves. The shelves accessible from the front will be about 15” x 15” and 1.5 feet high each. The back shelves will be accessible from the sides and will be about 30 inches wide and 15 inches deep. I may leave some out to allow for a hanging cabinet or something like that. The reason I’m asking about other people builds is because I plan to make this out of 3/4” melamine MDF. My estimate is that this will require 6.5 sheets of plywood. Unfortunately, if home depot’s website is right (and I think it is), The unit will weigh in at just over 600 lbs, not counting all the stuff I want to put on it. I’d really like to hear your thoughts. I wish I have a sketch-up diagram or something, but hopefully my explanation is clear. Thanks all! |
15 replies so far
#1 posted 1183 days ago |
7 ft high gun cabinet. Only weighs about 100 #, -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence |
#2 posted 1183 days ago |
16’ High, 24’ Long breakfront cabinet. I don’t like using MDF for anything structural. In my experience, even with a solid edging, it doesn’t hold the weight well. It starts to warp, sag, bow- whatever you want to call it, it doesn’t stay flat. It’s what IKEA and wally world build their junky furniture out of. You’ll also get a hernia trying to move it. -- Karen - a little bit of stupid goes a long way |
#3 posted 1183 days ago |
I think it’s 6’ tall, 3’ wide, and maybe 18” deep. It’s something I’ve been meaning to post as a project to LJs, but it has some problems I’m not proud of, like the doors swelling and not shutting right at all. Anyway, it has 2 front doors that are about 4” deep and internally lined with shelving standards and pegboard. It’s a mix of shelves and things hanging above shelves in each door from top to bottom. Inside, the cabinet is divided into a left and right half down the middle with a wall. The wall holds piano hinges for 2 more fridge-style doors inside that face out, so when you open the 2 main doors, you see 4 6’ tall sections of shelves, standards, and pegboard laid out before you. Then the inner doors can swing out and around revealing yet another section behind them. I love it, but my biggest gripes are the massive wood movement of the main doors that keeps them from shutting (I also think they might just be too heavy, even on 6’ tall piano hinges), and the fact that each of the 6 sections is only about 4” deep. There are so many things that can’t even close to fit in there. That’s why I built a wall cabinet, and why I continue to find new places to store my too many things :) -- Gary, Los Angeles, video game animator |
#4 posted 1183 days ago |
I mocked up something really rough in SketchUp to see if I got what you mean. Left side: Left 3/4: Right 3/4: Right side: Some of the measurements were a little weird, like your shelves on the right are 15” and 30” front to back, but that doesn’t add up to the 4’ depth. I used 30 and 18. Anyway, hope it’s close, and that it helps you visualize it. I agree that MDF is crazy heavy. It has no airspace. It’s a slab of hot-pressed glue, basically. Might be better to just frame it out with 1x and 2x material – just a skeleton – then divide up the areas with 1/4” ply or similar. MDF really takes a thrashing over time with wood sliding around on it. I have miter saw wing table tops made out of it, and they’re pretty crummy looking now. Also, any moisture, like green wood, or a wet rag will cause the melamine to bubble up and wrinkle, and it looks water damaged after that. If you want it, the file for this rapid, down-and-dirty mock-up is here. -- Gary, Los Angeles, video game animator |
#5 posted 1183 days ago |
A rolling cabinet, 7 feet tall, 4 feet wide, and 2 feet deep. It is made from 3/4 birch plywood and has heavy duty casters. It was my 1st project and still moves with ease and has no structural problems. Good Luck -- Randy, Allen Texas |
#6 posted 1183 days ago |
i agree with the comments about MDF, as well as the alternative of using a frame/panel system. |
#7 posted 1183 days ago |
This is the biggest piece that wasn’t attached to a wall (I assume that’s what you mean by freestanding) ... -- http://www.peteroxley.com -- http://north40studios.etsy.com -- |
#8 posted 1182 days ago |
Wow Gary, To those that posted their own project references: Thanks for providing these. It gives me hope that as long as I don’t plan to move this thing, I might just be ok. It won’t be so massive as to create it’s own gravitational field. To those that posted suggestions/comments: Here are the things people seem to not like: Alternative Construction Method |
#9 posted 1182 days ago |
Hokie, You are going to want to make the unit taller than 8’ if you are planning are putting a 4’x8’ sheet goods in the center bin. If the sides of the center bin is made from 8’ tall sheet goods, the 8’ sheets goods you try to store in it will in most case bind up. Leaving 1-2” clear above will make getting sheets in and out alot easier. Just a thought. Rob -- Rob-Yorktown "Shop's still not done, Tools are bought, Wood is bought, need to find time to start a project.." |
#10 posted 1182 days ago |
Rob, |
#11 posted 1182 days ago |
My built-in sheet good storage is 4’ wide, divided up into three sections. It is rare to have any bin completely filled up to alleviate leaning. I just keep some scrap 48” x 2”(or 3”, 4”,5”) widths of plywood and just wedge them in at the upper side of the sheets to keep them pressed together to stop any potential bowing. Rob -- Rob-Yorktown "Shop's still not done, Tools are bought, Wood is bought, need to find time to start a project.." |
#12 posted 1182 days ago |
Glad I could help, Hokie. I agree with your final point, too. I’ve had so many grand ideas for my storage solutions that then became rather plain and uninteresting after budget or time interfered. -- Gary, Los Angeles, video game animator |
#13 posted 1182 days ago |
sounds like me, gary. that’s resulted my in storing things in sturdy shoeboxes and ancient kitchen cabinets… it works, is all i can say. |
#14 posted 1182 days ago |
What is your celing height? Remember you can not stand up an 8 foot tall cabinet up in a room with an 8 foot celing and you can’t get it in the door standing up. -- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it. |
#15 posted 1182 days ago |
I’m not sure of the exact ceiling height, but its about 14 feet. One of the reasons I like this design is that the left side (when looking at it) will be up against a 4 foot stairway. that means the top shelves will just barely be above the railing so I can put stuff in the garage without having to put shoes on. LOL! |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15980 |
Hand Tools
2097 |
Jigs & Fixtures
501 |
Wood & Lumber
2908 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2777 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
