What 2-3 bandsaw blades?
Forum topic by dmorgantx posted 03-24-2010 05:04 AM 1252 views 3 times favorited 8 replies Add to Favorites Watch
View dmorgantx's profile
dmorgantx
70 posts in 3082 days
03-24-2010 05:04 AM
Topic tags/keywords: bandsaw question
I just picked up a used Grizzly 0457. I’ve never owned a bandsaw before and am a little overwhelmed by the bandsaw blade choices out there. I’m looking forward to learning though. I would like to be able to do a little bit of resawing (experimental stuff) and I would also like to be able to cut some general curves for push sticks, cabinets and other items. I would expect I’ll be working with a bit of pine and a bit of red oak. Other than that- I’m going to have to learn what I need.
So the question is- what would you recommend that I pickup to get started? I’m thinking all should probably be 1/2” or less, although technically the saw will take a 3/4 (sounds like it might be a little much for 14” saws based on what I’ve read). I’m thinking 1 woodslicer for resawing and 1 or 2 general purpose blades (gentle curves, ripping small pieces, etc).
So if you were me- what 2-3 blads would you pick up?
8 replies so far
View live4ever's profile
live4ever
983 posts in 3009 days
#1 posted 03-24-2010 05:12 AM
Take a look at this chart if you haven’t seen it yet – should give you an idea of what to get based on what you plan on cutting most and anticipated thicknesses of your material.
http://www.suffolkmachinery.com/silicon_steel_selection.asp
If you order three blades direct from Suffolk (makers of Timberwolf blades), you get a fourth for free.
Definitely get the Woodslicer. Nice saw btw.
View knotscott's profile
knotscott
8014 posts in 3374 days
#2 posted 03-24-2010 05:22 AM
+1 on calling Suffolk…
View David Kirtley's profile
David Kirtley
1286 posts in 2997 days
#3 posted 03-24-2010 05:42 AM
I tried a woodslicer and did not like it. I found the timberwolf blades took less tension, made a cleaner cut, and lasted longer.
View richgreer's profile
richgreer
4541 posts in 3073 days
#4 posted 03-24-2010 03:11 PM
I would advise you to get a 1/2 blade for resawing and I would advise you to not use for any curved work. Once you use it on curves, you may have trouble getting it to track straight for resawing.
For semi-tight curves, I like 3/16th. I find that the 1/8 blades do not hold up very long.
I also like Timberwolf.
knotscott
#5 posted 03-24-2010 03:24 PM
Forgot to mention that the folks at Suffolk will ask you a bunch of questions about your saw and what you cut, and will make some recommendations specifically for your situation, which makes a lot of sense to me….you don’t even have to ask for that help, it’s just SOP for them.
View Jon Spelbring's profile
Jon Spelbring
199 posts in 4252 days
#6 posted 03-24-2010 03:41 PM
Tip for curves – pick up a blade stone so that once the blade is on, you can round the back edges of the blade. It will give you a smoother cut, and a slightly tighter radius.
I’ve had great experiences with the folks at Suffolk. They’ll steer you in the right direction.
Congrats on the new saw!
-- To do is to be
View wiswood2's profile
wiswood2
1138 posts in 3695 days
#7 posted 03-24-2010 05:10 PM
I use nothing but 1/8 blade but I do a lot of tight turns.
Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
View michaelray's profile
michaelray
232 posts in 3453 days
#8 posted 03-24-2010 09:15 PM
I have a G0457 and I use a 3/4 for resawing and a 3/8 for general purpose work. The 3/8 came with the saw but I wouldn’t use it for tight curves. I plan to purchase a 3/16 and maybe a 1/8. The blades also came from Grizzly and this was also my first bandsaw. I can’t speak for the TW blades although I would like to try them based on all of the positive things I’ve heard on this site.
-- Michael@www.victorycoffin.com
