Sliding dovetails to tie two sections of an exterior door together
« back to Joinery forum
Forum topic by Gregg M. posted 04-21-2016 01:11 PM 623 views 0 times favorited 4 replies Add to Favorites Watch
View Gregg M.'s profile
Gregg M.
202 posts in 1650 days
04-21-2016 01:11 PM
Topic tags/keywords: question how to jig
I am making an entry door that was featured in an article by Fine Home Building. The article is called “Build a High-Performance Exterior Door” by Ben Graham and Mike Lamp. The plans call for a sandwiching two 3/4” doors between insulation. Sliding dovetails are used with cleats to tie the two separate doors together from the inside. I would like some thoughts on how best to go about milling the sliding dovetails. see pictures below. Both interior sides of each door require a dovetail. The plan also calls for a 30 degree dovetail. Does anyone know where to find a 30 degree dovetail bit?
The door
Inside of exterior side of door
Attaching interior side of door
Thanks,
Gregg
-- Marvel Woodworking, West Chester, PA - http://www.MarvelWoodworking.com
View BurlyBob's profile
BurlyBob
5419 posts in 2234 days
#1 posted 04-21-2016 02:19 PM
My suggestion is to call Whiteside. I’m pretty sure if they don’t have one they’ll mill you one.
View rwe2156's profile
rwe2156
2884 posts in 1449 days
#2 posted 04-21-2016 04:45 PM
My first thought is “why 30 degrees?” it sounds very strange to me the more acute the angle the weaker that long grain will be.
I think a standard 7-10 degree DT bit will work just as well.
Gregg M.
#3 posted 04-22-2016 06:59 PM
Thanks for the suggestion. I like Whiteside and buy most of my bits from them.
My suggestion is to call Whiteside. I m pretty sure if they don t have one they ll mill you one.
- BurlyBob
Gregg M.
#4 posted 04-22-2016 07:02 PM
In the article they say to use a 30 degree dovetail 1/4” deep. I guess it is due to the dovetail’s depth. But you are probably correct, that it it isn’t necessary.
- rwe2156
