Need help, powder post beetle / longhorn beetle in finished box.
Forum topic by Blackie_ posted 04-20-2016 11:31 PM 1460 views 0 times favorited 19 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4883 posts in 2747 days
04-20-2016 11:31 PM
Need some help and or advise, I just received a call from one of my customers with findings of fine sawdust in one of the drawers of a box I sold him, he’s not upset with the box and construction more so concerned. The wood in question is cedar elm air dried. The box walls are 5/8” thick finished with Tung oil and wipe on poly, the inside of the drawers are painted with enamel and flocked. So putting it in the oven might not be an option so would freezing be an option?
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
19 replies so far
View Roger's profile
Roger
20965 posts in 3038 days
#1 posted 04-20-2016 11:56 PM
How in the heck would they still be alive after all the finish is sealing them in?? Sorry, I don’t have an answer for ya, but, it’ll be interesting to hear some ideas
Blackie_
#2 posted 04-21-2016 12:19 AM
The customer sent me some pictures and the area he’s pointing out is from the kiln dried knotty alder, is it possible that larva could have survived the drying? Also that area of wood in the alder is but only 1/4” thick.
View Mrkixx's profile
Mrkixx
71 posts in 2214 days
#3 posted 04-21-2016 12:37 AM
Well I, living in Canada, would just try putting it in the freezer for a few days or so because if they are now not in larva stage then they may just freeze to death, however you might need to be careful with the box and see how it holds up to the change in temp maybe you could buy it back and see what happens for yourself or offer to make him a new one to replace that one, in the mean time find out which wood type is the problem and do some research to see what kind of creature it is and maybe you will find out what can be done to kill them off. You might also want to find another source for your stock , because chances are that other species could have the same problem. I’m really very interested to see and hear what the end result will be.
Blackie_
#4 posted 04-21-2016 12:42 AM
What about a hair dryer aimed at the target area?
View  woodshaver Tony C   's profile
woodshaver Tony C
6268 posts in 3587 days
#5 posted 04-21-2016 12:50 AM
Maybe calling a furniture fumigation service would have some answers for you Randy.
I also found this about half way down the page.
-- St Augustine FL, Experience is the sum of our mistakes!
View Jim Jakosh's profile
Jim Jakosh
21953 posts in 3340 days
#6 posted 04-21-2016 02:12 AM
Boy that’s a tough one, Randy with it being finished and all. I would have thought the kiln would have gotten hot enough to kill the beetles. Fumigating with a gas seems to be the best way but the microwave is worth a try because it will cook them for sure if the piece will fit in it. I’d be concerned for a glue joint, however.
Down at the Sawmill in Az, John sold a mesquite table to customer and she called him to say she heard something in the table. It was the bugs in the sapwood. He had to cut off all the sapwood and replace it with a contrasting wood. Bugs in mesquite can live 35 years and turn all the sapwood and some of the heart wood to yellow dust! I’m doing a table right now and the sapwood was dropping yellow dust for days. I wound up grinding all the bark and sap wood off and hit 12 white worms in there in the process. That wood was sitting in the sun for a long time at over 140 degrees sometimes so they can take heat!
Cheers, Jim
View SenecaWoodArt's profile
SenecaWoodArt
438 posts in 1854 days
#7 posted 04-21-2016 02:17 AM
Randy, my solution would be to double bag the box. On the inside bag, I would puncture with multiple small needle sized holes. Seal that bag shut with the box inside. Place the needle punctured bag into the next bag. Lightly spray the inside of that bag with an aerosol type insecticide and seal shut. Repeat the spray process every day for a week. That should resolve the problem. Remember, “light” spray is the key. You don’t want to saturate the box.
-- Bob
View AZWoody's profile
AZWoody
1419 posts in 1458 days
#8 posted 04-21-2016 02:18 AM
I have a lot of mesquite that I’ve milled that has beetles in it. I’m waiting it for it to get hot enough to make a hot box that I can hopefully get up to at least 150 degrees Fahrenheit. I’ve tried chemical treatments with borax based sprays and it killed some, but not all. Eventually, the dust piles would start coming again.
Freezing might work, but an oven I think would work faster and you can be sure. Some insects are pretty hardy and can go dormant in cold weather. No idea if those beetles can but why risk it?
Blackie_
#9 posted 04-21-2016 02:25 AM
After further speaking with the customer I’m pretty sure it’s not the kiln dried alder that the dust is coming from its the outside cedar elm which makes more sense since it was air dried. I’m keeping in contact with customer monitoring. Thanks for the suggestions. I need all the help I can get here as the customer really likes the box and doesn’t want to lose it.
View DocSavage45's profile
DocSavage45
8731 posts in 3077 days
#10 posted 04-21-2016 02:44 AM
Randy,
Is the box repairable? Can you construct a new one? I’ve run into the ash bore in my storage area. Can’t see them but I see the holes. Bought some insecticide that relies on boric acid. (safe for humans and pets) Naturally occurring insecticide.
You might request the box returned to fumigate it yourself, but that may not guarantee there will be no more bugs.
I’m sure you are going to rethink your processes.
Good luck!
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Monte Pittman's profile
Monte Pittman
30128 posts in 2572 days
#11 posted 04-21-2016 03:07 AM
I would think that heat would kill the bugs. 150° for maybe an hour.
Blackie_
#12 posted 04-21-2016 03:10 AM
Monte, would that amount of heat be ok on the wood and joints also finish?
DocSavage45
#13 posted 04-21-2016 03:55 AM
Randy,
Check this out.
http://www.epestsupply.com/powder-post-beetles.php#.VxhO3jArKhc
View splatman's profile
splatman
586 posts in 1633 days
#14 posted 04-21-2016 04:36 AM
To find out whether microwaving would be safe, build a small box with all the same woods, glues and finishes, and nuke it. Then show us the end results.
View WDHLT15's profile
WDHLT15
1797 posts in 2710 days
#15 posted 04-21-2016 11:35 AM
I would put it in the oven, too, at 150 degrees for 12 hours and take your chances. Powderpost beetles can live in wood for years. There is a chance that fumigation will not penetrate deep into the wood where the beetle larvae and eggs are.
At the end of my kiln cycle, I always run the temp to 150 degrees and hold it for 24 hours to sterilize the wood.
