Question about router jig for half-lap joints
Forum topic by WillInTheMill posted 03-23-2010 09:31 PM 6437 views 0 times favorited 3 replies Add to Favorites Watch
View WillInTheMill's profile
WillInTheMill
54 posts in 3144 days
03-23-2010 09:31 PM
Hi everyone! I’m building two router jigs to do half-lap joints for a project just like this one:
http://lumberjocks.com/projects/22815
I’ve never built a router jig before, and one that I made is really tight (the pieces are locked tight together), and the other is loose by about a 1/32” or 1/16” (there is some wiggle room) to the finished pieces. Which joint would be better for the finished project? Should I have some room for glue between the pieces, or do I want them ultra tight? I plan to fasten everything with glue and dowels. Thanks!
-- Will, Tampa, FL
3 replies so far
View Michael Murphy's profile
Michael Murphy
453 posts in 2972 days
#1 posted 03-23-2010 09:58 PM
Tighten it up with some shipping tape or even edge banding the inside edge of one of the edges of the looser one.
-- Michael Murphy, Woodland, CA.
View bobkberg's profile
bobkberg
439 posts in 3041 days
#2 posted 03-23-2010 10:00 PM
Does it have to be done with a router? For something like this, I’d rather use a table saw, and mark where the cuts go with a very sharp pencil.
When I do half-lap joins (even in small scale) I still use a table saw. Much as I like a router, I consider it to be a second or third choice for something like this that’s open. I’ve only used a router for doing half-lap cuts where I was working in a tight space.
As for how tight it should be – just enough space so the the pieces can be joined without force. If there is any “wiggle” room, the joint won’t look good, and may well fail.
HTH,
-- Bob www.singularengineering.com - A sideline, not how I earn a living
WillInTheMill
#3 posted 03-23-2010 10:36 PM
Hi Bob,
The upright pieces are about 7 feet long, and all I have is a cheap contractor folding table saw. The router jigs are already made and will be much easier to use, especially with the long pieces and 6 degree angle cuts. I agree that once I have a dado set it would be much easier. :)
Sounds like I need to tighten up the one and loosen up (or sand down) the tight one. Thanks!
And I’ll welcome any other answers of course. :)
-- Will, Tampa, FL
