Peppermill...without a lathe.
Forum topic by ghazard posted 03-23-2010 03:21 PM 1731 views 0 times favorited 4 replies Add to Favorites Watch
View ghazard's profile
ghazard
382 posts in 3535 days
03-23-2010 03:21 PM
Topic tags/keywords: pepper mill
What do you think? Is this possible? Any suggestions? I don’t have a lathe but want to make one for my sister’s wedding this fall.
I’m thinking a “box” structure with an inner dimension smaller than the min ID needed for the mill internals. I have a big drill press for boring the internals.
Then contour and shape the outside using roundover bits and such on a router table.
This idea is only about 15min old in my head so I’m trying to identify the issues I’ll run into.
Has anyone every tried this?
Thanks,
Greg
-- "Hey, you dang woodchucks! Quit chuckin' my wood!"
View dbhost's profile
dbhost
5726 posts in 3258 days
#1 posted 03-23-2010 03:42 PM
Nope. Haven’t tried it, but it sounds fascinating….
View Derek Lyons's profile
Derek Lyons
584 posts in 3594 days
#2 posted 03-23-2010 03:54 PM
I don’t see any problems offhand, it’s certainly worth a try. Be sure and use food safe glues when assembling the box.
-- Derek, Bremerton WA --
View PetVet's profile
PetVet
329 posts in 3513 days
#3 posted 03-23-2010 04:09 PM
I think this could be neat. Consider doing a 6 or 8 sided one, doing the glue up like you were making a slatted vase or bowl. Use a round over or beading bit on the top outside edge before glue up, maybe even fluting the sides. Then after glue up, use a forstner bit to drill the proper size holes in the top and bottom. I think it is doable, and would be quiet nice when done. Good luck!
-- Rich in Richmond -- Experience is something you don't get until just after you need it.
View CaptainSkully's profile
CaptainSkully
1600 posts in 3584 days
#4 posted 03-23-2010 04:15 PM
I’ve seen jigs that allow you to box in a piece of stock and use a spiral upcutting bit in a router to generate round turnings for columns on a fireplace. I’ve also seen someone rig up a drill on a bracket to make a small lathe.
-- You can't control the wind, but you can trim your sails
