Any experience with the Woodworker Woodtek 24" bandsaw?
Forum topic by GKP741 posted 03-23-2010 02:47 AM 3479 views 0 times favorited 5 replies Add to Favorites Watch
View GKP741's profile
10 posts in 2916 days
03-23-2010 02:47 AM
I was hoping someone has some experience with one of these. Have a chance to pick up a slightly damaged unit still on the pallet for about $300. Thanks for any input.
5 replies so far
View Michael Murphy's profile
Michael Murphy
453 posts in 2934 days
#1 posted 03-23-2010 04:40 PM
Looking at the spec’s. it appears to be a monster. Over half a ton of bandsaw with 15” resaw capacity.
I suppose it would depend on what the slight damage is. And whether you have a place to put something that big and have the electrical power to run it. (5 hp, 25 amp 220v)
-- Michael Murphy, Woodland, CA.
#2 posted 03-23-2010 07:19 PM
I have been building a workshop for almost five years now. It is mostly complete except the bathroom. 30 by 60 feet with 12’ walls. South end is milling, metal & welding area along with a 3/4 bath. Center is mechanic and open space. North section is woodworking with a gun room along the north wall. I have the room and power.
The upper guard door is bent badly. frame is straight, wheels and motor are fine. Blade guides missing.
Michael Murphy
#3 posted 03-23-2010 08:15 PM
Sounds like a good deal at 300 even if you have to spend a few hundred on new Blade Guides. Sounds like you could straighten out the door in your Metal and Welding area. I would probably buy it if I were you.
View sandfarm's profile
1 post in 3526 days
#4 posted 01-30-2011 04:42 PM
I just bought a used 1999 Woodtek 24” band saw?
Did you buy the Woodtek 24” band saw? If so, did you get an owner’s manual with yours?
I asked and received a few pages from Eric Fairfield at Woodworkers Supply, but these didn’t help much. The pages showed the part numbers without description and a blow out of the machine.
If you got an owners manual, would it be possible to obtain a copy?
Joe Isley
View woodman250's profile
1 post in 2594 days
#5 posted 02-08-2011 09:27 AM
I have a Woodtek 24” band saw. Manual sucks, the saw is a Taiwan copy of an old Meber Band saw that is made in Italy or Germany. The band saw cuts very well if you use Lenox blades. The quality of the saw is excellent except for the wheel castings, that are a little crude, but are well balanced. I replaced the euro guides with the Carter guide set made for a Meber SR600.
