Band Saw Circle Cutting Jig Problems
Forum topic by KevinVan posted 03-23-2010 02:46 AM 13569 views 0 times favorited 47 replies Add to Favorites Watch
View KevinVan's profile
91 posts in 3086 days
03-23-2010 02:46 AM
Topic tags/keywords: jig question
What do you guys use for cutting circles with a band saw and jig?
I built a simple jig last week and can’t get it to cut without stressing the blade. I placed the center point just in front of the blade like the examples I found online.
The blade I’m using is a new ½” wood slicer resaw blade from highland. I also tried a ¼” blade with the same results. I couldn’t believe how much the blade binded in the kerf.
I’m using mostly cherry, walnut and maple.
I ended up free handing the circles and then used the jig clamped on the sander to make it round. This worked well!
So what am I doing wrong? Do I need a different blade? Should the pivot point be moved forward?
-- ALS IK KAN “to the best of my ability,”
47 replies so far
View 1yeldud1's profile
301 posts in 2977 days
#1 posted 03-23-2010 03:10 AM
What size radius were you trying to cut ???
#2 posted 03-23-2010 03:18 AM
Radius would be 8 1/4” or 16 1/2 diameter. My Bandsaw is a 14” Powermatic.
View rsmith71's profile
269 posts in 2977 days
#3 posted 03-23-2010 03:47 AM
I freehanded my bowls on the bandsaw and sanded them smooth. I found that marking them inpencil them making stright-in relief cuts every so often (no set places, just where ever looked good) from the sides kept the blade from binding or wandering nearly so much.
-- Robert - Haven Wood Crafts
View Alex Lane's profile
Alex Lane
484 posts in 3825 days
#4 posted 03-23-2010 04:10 AM
The guys who have woodworking shows on TV like Norm Abrams and Scott Phillips usually use a bandsaw jig for circles 2 to 3 or more feet in diameter. At least I don’t remember seeing them use a bandsaw for a diameter as small as yours. I think they both use a router on a circle-jig for the smaller circles.
Maybe that’s no help to you, but it might vaguely explain your difficulties…
I think that the way you worked it out—freehand, followed by sanding with the jig—was very excellent use of an alternate technique. To me, that’s the beauty of woodworking…there’s definitely more than one way to ‘skin a cat’—or slice a board—whichever you prefer… ;-D
Your frustration is understandable, but sometimes what works for some people just doesn’t pan out for others. I’m usually in the ‘others’ group, so I often find another way to effectively do what I want in the shop. I end up being even more satisfied with the result because of the journey I took to get there.
Keep it up!!
-- Lane Custom Guitars and Basses
#5 posted 03-23-2010 04:35 AM
On that small of a radius I would place the jig on the “dead” centerline of the blade. I then would make an initial cut aprox. 1/4” inside or outside (depending on which section you are saving) then I would re-set the jig as you origionaly did and cut the radius to the desired size. I beleive with that small of a radius you must clear the stock out of the saw kurf to eliminate the binding
View lew's profile
11989 posts in 3690 days
#6 posted 03-23-2010 05:24 AM
I regularly cut circles much smaller than yours with my jig.
My stock thickness is usually equal or less than 1”, but as much as 3”. I usually use a 1/4” blade but sometimes a 3/8”.
For the least amount of binding, the center line of the jig should be at the front of the blade teeth.
Make sure the tension is correct. Sometimes the blade drift can tend to pull away from the cut and cause this to happen. Take it slow and easy.
View closetguy's profile
744 posts in 3827 days
#7 posted 03-23-2010 06:03 AM
The size of the circle has nothing to do with it. A 2” circle will cut the same as a 36”. I believe a 1/2” blade is too wide for cutting circles. I use a 1/4”. I also can’t see the center line in reference to the teeth having anything to do with binding. Once the stock is turned into the blade you should be able to spin the stock pretty quick. The only things I could think that could cause binding would be a dull blade, the stock not sitting flat on the table, or the table not square to the blade. Check your setup, because like Lew said, not enough blade tension could contribute to it also.
-- I don't make mistakes, only design
View russv's profile
262 posts in 3104 days
#8 posted 03-23-2010 06:20 AM
i also own a powermatic bandsaw. i have cut circles out many times using the method you described and never have a problem. i would suspect something in the way your saw is tuned might be the problem.
you might moving the pivot point around to see how it changes the tracking. make sure your bearings above and below the table are rolling free and are adjusted properly. blade alignment is critical.
it has to be in the saw set up some how.
-- where to go because you don't want no stinking plastic!
View TheDane's profile
5384 posts in 3597 days
#9 posted 03-23-2010 02:09 PM
I ran into a similar problem last weekend … found a video on Stu’s Shed that showed a jig that worked pretty well for me. (
Alex Lane
#10 posted 03-23-2010 02:17 PM
I apologize if I was misleading in what I said above. I was speaking from a non-experienced perspective, and it might have been better if I kept my mouth shut…LOL
It seems that I really had no idea what I was talking about as far as the size of circle a bandsaw can cut, so I’m sorry. But I’m sticking to the “more than one way to skin a cat” line of reasoning!! ...Those poor skinless cats. ;-D
I’ve never yet had a project that called for cutting circles in wood, but it may come up in my shop in the future.
I hope you can get this worked out successfully!!
View Michael Murphy's profile
Michael Murphy
453 posts in 2940 days
#11 posted 03-23-2010 04:11 PM
I agree with Closetguy, 1/2” is too wide a blade. Tension and tracking and a nice sharp blade are the key to getting that to work. Try adjusting the tracking slightly and see if it improves. Since the top wheel is crowned, where the blade runs over the wheel determines how parallel it runs in relation to the edge of the table.
I have used a circle jig lots of times on my PM 14”. Smaller radii too.
-- Michael Murphy, Woodland, CA.
View donjoe's profile
1360 posts in 2965 days
#12 posted 03-23-2010 04:24 PM
I cut 10” and 12” circles with no problem using a 1/4”blade. The only thing is I have to enter the work piece right on the cut line. If I try to start by making the blade come to the cut line I have the problem you are talking about. Most of the vids I’ve seen (if you watch closely ) they have the starting spot right on one edge of the stock cut line even if they have a certian portion of waste on three sides.
-- Donnie-- listen to the wood.
View PurpLev's profile
8534 posts in 3583 days
#13 posted 03-23-2010 04:44 PM
you are using a 1/2” RESAW blade – which is great for RESAWING as it’s wide and likes to stay true to the STRAIGHT cut line. but WILL have a hard time doing curved cuts as it’s not meant for those.
use 1/4” blade or narrower (I use a 3/16” blade for scroll work and curved cuts)
#14 posted 03-23-2010 08:05 PM
If the gentleman doesnt want to purchase a 2nd blade he can set up and remove the majority of the stock using straight cuts until he is about 1/16 away from the line – then set up his jig and use his existing blade – I agree that the 1/2 inch blade is too wide but I think he can make this blade work by making multiple cuts
View Hoakie's profile
306 posts in 3970 days
#15 posted 03-23-2010 08:30 PM
Have you tried filing the back of you blade to round over the edges . This can make a big difference
-- John H. [To invent, you need a good imagination and a pile of junk. ~Edison]
showing 1 through 15 of 47 replies
