drying lumber in the attic
Forum topic by pmayer posted 1155 days ago 1432 views 0 times favorited 5 replies Add to Favorites Watch
View pmayer's profile
pmayer
377 posts in 1232 days
1155 days ago
Topic tags/keywords: lumber drying attic
I am considering using the attic above my shop to store lumber (2×10 attic trusses, so weight is not a concern), and I was wondering if there would be any problems in drying lumber up there. Am I asking for an infestation problem by doing this? Should I run a fan up there to accelerate the drying? Any other tips?
5 replies so far
View Daren Nelson's profile
Daren Nelson
767 posts in 2073 days
#1 posted 1155 days ago
If it gets hot and is ventilated, sure that is a great place to dry wood. Yes if the wood has bugs…then you are introducing them to plenty of more food, like your building framing. So if you suspect bugs I would not do it. A fan would not hurt.
-- http://nelsonwoodworks.biz/
View mics_54's profile
mics_54
581 posts in 1638 days
#2 posted 1155 days ago
How do you know weight isn’t a concern? Attic trusses do have live and dead load weight limits. Do you know the designed loads. I am assuming when you say 2×10 attic trusses you are refering to the bottom cords or floor joists in the attic section. I notice from your profile you are located in MN which obviously means varying snow loads also.
Perhaps the amount of lumber you are talking about is very minimal?
I wouldn’t think infestation would be a huge issue. (if you don’t put bugs up there) I would be more concerned about introducing bugs to the trees at your location than the attic of your shop.
Additional air flow would certainly help. I’m assuming that the attic isn’t a finished space that could be humidity controlled.
-- Dan, Sterling Alaska, Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
pmayer
#3 posted 1154 days ago
Thanks for the input so far, guys.
Darren, yep, well ventilated.
Dan, good point on the trusses; they certainly do have their limits, but the amount of lumber that I have in mind will not approach their capacity. Probably a few hundred board feet in a 16×24 space. The only reason that I mentioned it is that in 2×4 construction it could be a problem even in those quantities.
I am not planning to finish the attic space to the point where I can control the humidity at this time. Maybe someday, but not in the next five years.
View okwoodshop's profile
okwoodshop
386 posts in 1342 days
#4 posted 1154 days ago
Paul, I have been drying lumber in my shop attic for years. I always spread it out over the whole attic in three to four layers thick with sticks in between each layer. never had a bug problem except lady bugs here in the south, but they come into houses in the fall anyway. I have two large doors on each end that I can open to allow ventilation or close when its cold. You will be amazed how fast wood will dry up there. You could add a fan but I haven’t needed one yet.
View Dennisgrosen's profile
Dennisgrosen
10854 posts in 1282 days
#5 posted 1154 days ago
you can do it but remmember the stickers between and a top layer
to prevent warping and don“t forget a fan
then you will use the same ideas as if you have a solarkiln look here
http://www.woodscience.vt.edu/about/extension/vtsolar_kiln/
hopethis can help you
Dennis
